[Live-demo] gdal version on live dvd
Alex Mandel
tech_dev at wildintellect.com
Sat Jul 9 02:42:32 EDT 2011
We made a compromise and now do every other Ubuntu release (we used to
change every release). Only doing LTS releases would mean we expect
users to also only use LTS, which seems unrealistic.
I don't pretend to understand either of the fixes, however if you can
get a working package into the ubuntugis ppa we will take it. I believe
the tiff problem resolution is being worked on, and several applications
expect 1.8 and some of it's new features. So we should concentrate on
getting 1.8 working (See previous threads on the topic).
Thanks,
Alex
On 07/08/2011 11:27 PM, Johan Van de Wauw wrote:
> During testing, I noticed that also saga has the same tiff problems
> when linked to gdal 1.8. So I could also build with the standard
> distribution package, but that one actually also has quite a bad bug:
> it doesn't open gml files [0]
> Fixing the latter bug is very easy (only a rebuild is needed) and I'm
> willing to provide an updated package on a ppa, but I just want to
> cross check with the list if that is ok.
> Or perhaps it is better to fix gdal 1.8, and use that for all
> applications? I actually like that approach better.
> Johan
> PS: This bug isa typical bug in ubuntu due to their too short release
> terms. It is too late now, but I think it is wiser to stick to debian
> stable or ubuntu LTS releases for the live dvd.
> [0] https://bugs.launchpad.net/ubuntu/+source/gdal/+bug/786790
> On Tue, Jun 28, 2011 at 10:27 AM, Julien Malik <julien.malik at c-s.fr> wrote:
>> Hello
>> Thanks to all for your answers.
>> To avoid disturbing the disc alpha release process, we will change the otb
>> install script so that it uses the otb packages built with the standard
>> distribution packages (gdal 1.6).
>> In the meantime, I'll change our patch to fit Even's changeset, and propose
>> it for inclusion in the ubuntugis gdal package.
>> If it is accepted, we will be able to switch the OTB package to the
>> ubuntugis-enabled one (we have one PPA for each version).
>> Regards,
>> Julien
>> Le 27/06/2011 23:50, Hamish a écrit :
>>> Even wrote:
>>>> Well, you didn't read my previous email probably.
>>> (I hadn't)
>>>> It is upstream. See
>>>> http://trac.osgeo.org/gdal/ticket/4101
>>>> and
>>>> http://trac.osgeo.org/gdal/changeset/22461
>>> ok, so the solution would seem to be to try& convince Alan to
>>> get the patch backported into ubuntugis,& so fixed (well,
>>> sidestepped) for all, not just us.
>>> thanks,
>>> Hamish
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
