5.0alpha4 [Re: [Live-demo] 5.0alpha3 status]
Angelos Tzotsos
gcpp.kalxas at gmail.com
Mon Jul 11 14:16:31 EDT 2011
Hello Hamish,
Just fixed the issue with pycsw installer.
Thanks for the review.
Angelos
On Sat, Jul 9, 2011 at 5:04 AM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> just looking through the latest 5.0alpha4 build logs, here's what I notice.
> It seems like a number of these have already been fixed
> in the last day or two; if so, nevermind..
> (projects should be checking this themselves each time because
> sometimes a change to something else before your installer run
> may break things for you, and you know better than anyone what a
> successful install log should look like)
> everyone:
> start at the end of the build log, and look at the collection of
> error messages for anything which looks like you.
> install_edutools.sh: "eric" is a fairly big package (26mb). Will the IDE
> be used on the disc as part of someone's workshop?
> missing desktop icons: (not found in $USER/Desktop/ after installs)
> mv: cannot stat `gvsig.desktop': No such file or directory
> mv: cannot stat `atlasstyler.desktop': No such file or directory
> mv: cannot stat `mapguide*.desktop': No such file or directory
> mv: cannot stat `*[Rr]asdaman*.desktop': No such file or directory
> mv: cannot stat `monteverdi.desktop': No such file or directory
> big packages to maybe-remove: (not sure if it's clean to do so)
> gnome-user-guide (50mb)
> smbclient (40mb) [ftp-like CLI tools]
> oxygen-icon-theme (30mb) [prob just need to pick 1 theme to install]
> elementary-icon-theme (27mb)
> app-install-data (27mb) [alternative to Ubu Software Center in place?]
> humanity-icon-theme (19mb)
> xfwm4-themes (16mb)
> gnome-icon-theme (11mb)
> libsane (11mb)
> doc translators:
> 991(!) occurances: (WARNING/2) Title underline too short.
> -> make sure ReST underlines match subheading length
> libLAS:
> you're not in main.sh so not installed. should you be?
> GeoMajas:
> FIXME: Do not use chmod 777 if at all possible.
> uDig:
> http://udig.refractions.net/files/downloads/udig-1.2.2.html:
> 2011-07-06 15:00:06 ERROR 404: Not Found.
> openJump:
> FIXME: don't use wget for local files, just copy from local svn checkout.
> gvSig:
> E: Unable to locate package gvsig
> (seems fairly major)
> osm: (no action required?)
> osmarender breakage due to temporary DNS error on Alex's build machine?
> pgRouting:
> osm2pgrouting is very noisy. can anything be done about that?
> Sahana:
> python: no process found
> dropdb: database removal failed: ERROR: database "sahana" does not exist
> (but that's just pre-emptive cleanup, so ignore, right?)
> wants celery installed?
> Traceback (most recent call last):
> File "web2py.py", line 19, in <module>
> gluon.widget.start(cron=True)
> File "/usr/local/lib/web2py/gluon/widget.py", line 808, in start
> import_models=options.import_models, startfile=options.run)
> File "/usr/local/lib/web2py/gluon/shell.py", line 200, in run
> execfile(startfile, _env)
> File "applications/eden/static/scripts/tools/compile.py", line 33, in
> <module>
> compile_application(folder)
> File "/usr/local/lib/web2py/gluon/compileapp.py", line 506, in
> compile_application
> os.mkdir(os.path.join(folder, 'compiled'))
> OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
> addgeometrycolumn
> Ushahidi:
> tar: A lone zero block at 17095
> ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using
> password: YES)
> ...is that anything to worry about?
> Mapfish: (not really sure how many of these matter)
> ...some download errors
> Getting distribution for 'cssmin==0.1.4'.
> warning: no previously-included files matching '.DS_Store' found anywhere
> in distribution
> (Mac?)
> ... (many more)
> dropdb: database removal failed: ERROR: database "v2.2_mapfishsample" does
> not exist
> R-stats:
> The following packages have unmet dependencies:
> r-cran-vr : Depends: r-cran-mass but it is not going to be installed
> Depends: r-cran-class but it is not going to be installed
> E: Broken packages
> ERROR: dependency 'graph' is not available for package 'RBGL'
> ERROR: configuration failed for package 'rggobi'
> Ossim:
> (probably fairly major breakage, only gdal 1.6.0 and 1.8.0 are avail)
> E: Unable to locate package libgdal1-1.7.0
> E: Couldn't find any package by regex 'libgdal1-1.7.0'
> E: Unable to locate package libgdal1-1.7.0-grass
> E: Couldn't find any package by regex 'libgdal1-1.7.0-grass'
> tar: ossim/quickstart: Cannot open: File exists
> tar: Exiting with failure status due to previous errors
> WARNING: timestamping does nothing in combination with -O. See the wget
> manual for details.
> ./install_ossim.sh: 175: ossim-img2rr: not found
> chmod: cannot operate on dangling symlink
> `/usr/local/share/ossim/ossimPlanetUsers.pdf'
> 52nSOS:
> mv: cannot stat `/tmp/build_52nSOS/52nSOS.war': No such file or directory
> chown: cannot access `/var/lib/tomcat6/webapps/52nSOS.war': No such file or
> directory
> otb:
> (probably fairly major breakage)
> E: Unable to locate package otb
> cp: cannot stat `/usr/share/applications/monteverdi.desktop': No such file
> or directory
> chown: cannot access `/home/user/Desktop/monteverdi.desktop': No such file
> or directory
> Rasdaman:
> ---always add svn commit log messages, please---
> (probably fairly major breakage; now fixed?)
> ... http://www.rasdaman.com/Download/rasdaman_2011-03-17.tgz
> 2011-07-06 18:21:25 ERROR 404: Not Found.
> tar (child): rasdaman_2011-03-17.tgz: Cannot open: No such file or
> directory
> tar (child): Error is not recoverable: exiting now
> tar: Child returned status 2
> tar: Error is not recoverable: exiting now
> cd: 62: can't cd to rasdaman
> ./install_rasdaman.sh: 65: ./configure: not found
> make: *** No rule to make target `install'. Stop.
> ERROR: package install failed.
> pycsw:
> the wget manual for details.
> pywps:
> "export FOO=bar" in wrapper script is a Bashism.
> Use "FOO=bar; export FOO" instead.
> install_gisdata.sh:
> Starting AtlasStyler...
> log4j:WARN No appenders could be found for logger
> (org.geopublishing.atlasStyler.ASProps).
> log4j:WARN Please initialize the log4j system properly.
> Not starting GUI because command line parameter addFix was passed
> (many of these)
> install_language.sh:
> E: Unable to locate package xfkc (no longer exists, do we need to find an
> alternative?)
> zh -> chose simplified instead of traditional. ok?
> tinyows:
> put XML setup into /usr/local/share/tinyows/ and not /etc?
> thanks,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110711/d1d318c2/attachment.html
More information about the Live-demo
