5.0alpha4 [Re: [Live-demo] 5.0alpha3 status]
Pirmin Kalberer pi_ml at sourcepole.com
Mon Jul 11 16:53:10 EDT 2011
Hi Hamish,
Am Samstag, 9. Juli 2011, 04.04:20 schrieb Hamish:
> install_edutools.sh: "eric" is a fairly big package (26mb). Will the IDE
> be used on the disc as part of someone's workshop?
I've included eric for workshops like mine at FOSS4G:
http://2011.foss4g.org/sessions/new-features-qgis-power-users
But since I will need even more packages like qt4-designer, I will install
them during the workshop. Will remove eric from install_edutools.sh.
> tinyows:
> put XML setup into /usr/local/share/tinyows/ and not /etc?
tinyows.xml is the main configuration of tinyows and putting it somewhere else
than /etc will need additional configuration. In the next package release of
tinyows I will omit the tinyows.xml example in /etc because it needs sample
postgis data, which is usually not available.
Regards
Pirmin
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
Pirmin Kalberer
More information about the Live-demo mailing list
