[Live-demo] Mapfish - 5.0 beta2 - no database ?
maplabs at light42.com
Mon Jul 25 16:50:32 EDT 2011
Mapfish fails to launch - apache error log showsthe following
also, searching for installed postgres databases shows
user at osgeo-live:~$ psql -l | grep fish
[Mon Jul 25 14:47:41 2011] [error]
/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py:1129: SAWarning: The classname 'Poi' is already in the registry of this declarative base, mapped to <class
'mapfishsample.model.Poi'>
[Mon Jul 25 14:47:41 2011] [error] _as_declarative(cls, classname,
cls.__dict__)
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] mod_wsgi
(pid=1244): Target WSGI script
'/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi'
cannot be loaded as Python module.
(pid=1244): Exception occurred processing WSGI script
'/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi'.
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] Traceback (most
recent call last):
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] File
"/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi",
line 46, in <module>
application = loadapp("config:" + configfile)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 203, in
loadapp
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] return
loadobj(APP, uri, name=name, **kw)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 224, in
loadobj
context.create()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 617, in
create
self.object_type.invoke(self)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 109, in
invoke
fix_call(context.object, context.global_conf, **context.local_conf)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/util/fixtypeerror.py", line 57, in
fix_call
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] val =
callable(*args, **kw)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/middleware.py",
line 37, in make_app
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] config =
load_environment(global_conf, app_conf)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/environment.py",
line 49, in load_environment
init_model(engine)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/model/__init__.py",
line 16, in init_model
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] class
Poi(Base, GeometryTableMixIn):
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py", line 1129, in
__init__
_as_declarative(cls, classname, cls.__dict__)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py", line 1027, in
_as_declarative
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] **table_kw)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/schema.py", line 265, in
__new__
table._init(name, metadata, *args, **kw)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/schema.py", line 324, in
_init
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] self,
include_columns
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/base.py", line 2218, in
run_callable
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] conn =
self.contextual_connect()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/base.py", line 2284, in
contextual_connect
self.pool.connect(),
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 209, in
connect
_ConnectionFairy(self).checkout()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 370, in
__init__
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] rec =
self._connection_record = pool._do_get()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 696, in
_do_get
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] con =
self._create_connection()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 174, in
_create_connection
_ConnectionRecord(self)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 255, in
__init__
self.connection = self.__connect()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 315, in
__connect
connection = self.__pool._creator()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/strategies.py", line 80, in
connect
dialect.connect(*cargs, **cparams)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/default.py", line 275, in
connect
self.dbapi.connect(*cargs, **cparams)
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] OperationalError:
(OperationalError) FATAL: database "v2.2_mapfishsample" does not exist
[Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] None None
More information about the Live-demo
