[Live-demo] Mapfish - 5.0 beta2 - no database ?
maplabs at light42.com
Sun Jul 31 00:48:51 EDT 2011
Unfortunately, it appears that this is still the case for 5.0 beta3
looking in the postgresql logs, I see the attempts to remove the
database, and to connect to i
but no sign of an attempt to install it...
ideas?
Brian Hamlin
GeoCal
OSGeo California Chapter
415-717-4462 cell
On Mon, 25 Jul 2011 16:50:32 -0400, maplabs at light42.com wrote:
Mapfish fails to launch - apache error log showsthe following
> also, searching for installed postgres databases shows
> user at osgeo-live:~$ psql -l | grep fish
> [Mon Jul 25 14:47:41 2011] [error]
> /usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py:1129: SAWarning: The classname 'Poi' is already in the registry of this declarative base, mapped to <class
> 'mapfishsample.model.Poi'>
> [Mon Jul 25 14:47:41 2011] [error] _as_declarative(cls,
> classname, cls.__dict__)
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] mod_wsgi
> (pid=1244): Target WSGI script
> '/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi'
> cannot be loaded as Python module. [Mon Jul 25 14:47:41 2011] [error]
> [client 127.0.0.1] mod_wsgi (pid=1244): Exception occurred processing
> WSGI script
> '/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi'.
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] Traceback (most
> recent call last):
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] File
> "/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi",
> line 46, in <module>
> application = loadapp("config:" + configfile)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 203, in
> loadapp
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] return
> loadobj(APP, uri, name=name, **kw)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 224, in
> loadobj
> context.create()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 617, in
> create
> self.object_type.invoke(self)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py", line 109, in
> invoke
> fix_call(context.object, context.global_conf, **context.local_conf)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/util/fixtypeerror.py", line 57, in
> fix_call
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] val =
> callable(*args, **kw)
> "/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/middleware.py",
> line 37, in make_app
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] config
> = load_environment(global_conf, app_conf)
> "/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/environment.py",
> line 49, in load_environment
> init_model(engine)
> "/usr/local/lib/mapfish/MapfishSample/mapfishsample/model/__init__.py", line
> 16, in init_model
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] class
> Poi(Base, GeometryTableMixIn):
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py", line 1129, in
> __init__
> _as_declarative(cls, classname, cls.__dict__)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py", line 1027, in
> _as_declarative
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] **table_kw)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/schema.py", line 265, in
> __new__
> table._init(name, metadata, *args, **kw)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/schema.py", line 324, in
> _init
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] self,
> include_columns
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/base.py", line 2218, in
> run_callable
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] conn =
> self.contextual_connect()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/base.py", line 2284, in
> contextual_connect
> self.pool.connect(),
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 209, in
> connect
> _ConnectionFairy(self).checkout()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 370, in
> __init__
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] rec =
> self._connection_record = pool._do_get()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 696, in
> _do_get
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] con =
> self._create_connection()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 174, in
> _create_connection
> _ConnectionRecord(self)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 255, in
> __init__
> self.connection = self.__connect()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/pool.py", line 315, in
> __connect
> connection = self.__pool._creator()
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/strategies.py", line 80, in
> connect
> dialect.connect(*cargs, **cparams)
> "/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.1-py2.7-linux-i686.egg/sqlalchemy/engine/default.py", line 275, in
> connect
> self.dbapi.connect(*cargs, **cparams)
> OperationalError: (OperationalError) FATAL: database
> "v2.2_mapfishsample" does not exist
> [Mon Jul 25 14:47:41 2011] [error] [client 127.0.0.1] None None
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
