[Live-demo] 5.0alpha2 build logs
Hamish
hamish_b at yahoo.com
Sun Jun 26 00:55:21 EDT 2011
Alex wrote:
> http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
> Went a little better than last time. I had to manually
> interrupt and restart it (though not clean) somewhere towards
> the end of Java stuff.
thanks,
> Opps sorry I didn't up the version on the alpha build (I
> always forget that each new cycle).
semi-bumped now. a build-checklist.txt in svn might help ..
> If the logs look decent after a day I'll go ahead and pack
> a vm for people to download to make future testing of scripts
> easier on the 5.0 version.
still propagating packaging errors in this one leaving the
system in a broken state...
5.0a2 quick build log review:
everyone:
${CURLY} brackets do nothing to protect the command line from
spaces and special chars within variables. Use "double quotes"
for that.
geoserver:
FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's #!/bin/sh (which is dash)
geomajas:
GeoMajas FIXME: Do not use 777 if at all possible.
geonetwork:
any way to make your 250mb package smaller?
deegree, openjump, maptiler:
FIXME: don't use wget for local files, just copy from local svn checkout: cp ../app-conf/$FILE $DEST
gvSIG:
> mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or directory
etc.
osm:
temporary DNS trouble, now fixed?
Static copy of Denver.osm.bz2 now stashed on OSGeo download server, note
many times bigger than Barcelona, which may make the PostGIS DB
huge?
Sahaha:
a number of errors, e.g.:
> DataError: value too long for type character varying(64)
> OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
Ushahidi:
> ... Ushahidi already downloaded
> tar: A lone zero block at 17095
(probably want to do a timestamp check with the wget, but -N and -O are
mutually exclusive)
> ERROR 1045 (28000): Access denied for user 'root'@'localhost'
there is no root password. try operating as another user name.
geopublisher, atlasstyler:
> E: Package 'geopublishing-doc' has no installation candidate
mapfish:
> Download error: [Errno -2] Name or service not known -- Some packages may not be found!
script is very verbose, making it hard to pick out real error
messages.
mapguide:
.debs need to be updated for Ubuntu 11.04, ie to not depend on odbcinst1debian1
Uses a disproportionate amount of disc space (>375mb). please
find ways to slim it down.
[after this all other deb installs are broken for the rest of the ISO build..]
ossim:
wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
-> rebuild for natty
WARNING: wget -N timestamping does nothing in combination with -O.
52nSOS:
please shut off pgsql verbose mode & fix errors, if possible.
otb:
fails-- no packages for ubuntu/natty found in PPA.
[after this even less of the apt system works...]
disc space:
can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
+ linux-headers-2.6.38-8-generic (10mb)
(is building the proprietary nvidia driver a critical need?)
Hamish
More information about the Live-demo
