[Live-demo] 5.0alpha2 build logs
Julien Malik julien.malik at c-s.fr
Mon Jun 27 11:31:52 EDT 2011
Hello,
One important point for OTB on OSGeoLive :
We hit a wall with the gdal 1.8 package provided in ubuntugis-unstable
repository : it breaks TIFF support for applications linking to both
gdal and tiff, which is the case for OTB, making the OTB packages pretty
much useless.
This issue has been discussed on gdal-dev ML.
The debian packager of gdal is working on a solution to this known
problem, but it is not yet out.
The solution we chose for the OTB debian package is to patch the gdal
source package, and provide a patched binary package on the
orfeotoolbox-nightly PPA (here :
https://launchpad.net/~otb/+archive/orfeotoolbox-nightly
<https://launchpad.net/%7Eotb/+archive/orfeotoolbox-nightly>).
For those interested, the patch is here :
http://hg.orfeo-toolbox.org/OTB-DevUtils/file/tip/Packaging/ubuntu/gdal/do_not_disable_GTIFF_for_otb
It is harmless : it's only aim is to recover the behavior of gdal < 1.8,
where the TIFF driver was still registered, even in case of conflicts
with the gdal internal Tiff version.
When the release will be out in a few days, we will copy this binary
over to the orfeotoolbox-stable-ubuntugis PPA, which is used during the
OSGeo Live installation procedure.
In particular, it will spread out as the default gdal on the OSGeo Live CD.
I don't like it a lot, but we don't have a better solution coming to mind.
Meanwhile, I'm confident about the fact that the patch has no
functionnal impact on gdal.
What is your opinion ?
Julien
Le 27/06/2011 09:03, Manuel Grizonnet a écrit :
> Hi,
> concerning otb, the library is in the release candidate process. The
> release 3.10 is planned for the 06/30. I hope that Ubuntu Natty
> packages will be available just after that (orfeotoolbox-nightly
> packages already work on Natty :
> I'll send more informations at the end of the week.
> Regards,
> Manuel
> 2011/6/26 Hamish <hamish_b at yahoo.com <mailto:hamish_b at yahoo.com>>
>     Alex wrote:
>     > http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
>     > Went a little better than last time. I had to manually
>     > interrupt and restart it (though not clean) somewhere towards
>     > the end of Java stuff.
>     thanks,
>     > Opps sorry I didn't up the version on the alpha build (I
>     > always forget that each new cycle).
>     semi-bumped now. a build-checklist.txt in svn might help ..
>     > If the logs look decent after a day I'll go ahead and pack
>     > a vm for people to download to make future testing of scripts
>     > easier on the 5.0 version.
>     still propagating packaging errors in this one leaving the
>     system in a broken state...
>     5.0a2 quick build log review:
>     everyone:
>     ${CURLY} brackets do nothing to protect the command line from
>     spaces and special chars within variables. Use "double quotes"
>     for that.
>     geoserver:
>     FIXME: 'export FOO=bar' is a Bashism and will not work with
>     Ubuntu's #!/bin/sh  (which is dash)
>     geomajas:
>     GeoMajas FIXME: Do not use 777 if at all possible.
>     geonetwork:
>     any way to make your 250mb package smaller?
>     deegree, openjump, maptiler:
>     FIXME: don't use wget for local files, just copy from local svn
>     checkout:  cp ../app-conf/$FILE $DEST
>     gvSIG:
>     > mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or
>     directory
>     etc.
>     osm:
>     temporary DNS trouble, now fixed?
>     Static copy of Denver.osm.bz2 now stashed on OSGeo download
>     server, note
>     many times bigger than Barcelona, which may make the PostGIS DB
>     huge?
>     Sahaha:
>     a number of errors, e.g.:
>     > DataError: value too long for type character varying(64)
>     > OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
>     Ushahidi:
>     > ... Ushahidi already downloaded
>     > tar: A lone zero block at 17095
>     (probably want to do a timestamp check with the wget, but -N and
>     -O are
>     mutually exclusive)
>     > ERROR 1045 (28000): Access denied for user 'root'@'localhost'
>     there is no root password. try operating as another user name.
>     geopublisher, atlasstyler:
>     > E: Package 'geopublishing-doc' has no installation candidate
>     mapfish:
>     > Download error: [Errno -2] Name or service not known -- Some
>     packages may not be found!
>     script is very verbose, making it hard to pick out real error
>     messages.
>     mapguide:
>     .debs need to be updated for Ubuntu 11.04, ie to not depend on
>     odbcinst1debian1
>     Uses a disproportionate amount of disc space (>375mb). please
>     find ways to slim it down.
>     [after this all other deb installs are broken for the rest of the
>     ISO build..]
>     ossim:
>     wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
>     -> rebuild for natty
>     WARNING: wget -N timestamping does nothing in combination with -O.
>     52nSOS:
>     please shut off pgsql verbose mode & fix errors, if possible.
>     otb:
>     fails-- no packages for ubuntu/natty found in PPA.
>     [after this even less of the apt system works...]
>     disc space:
>     can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
>     + linux-headers-2.6.38-8-generic (10mb)
>     (is building the proprietary nvidia driver a critical need?)
>     Hamish
>     _______________________________________________
>     Live-demo mailing list
>     Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/live-demo
>     http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110627/9379ffd2/attachment-0001.html
More information about the Live-demo mailing list
