[Live-demo] 5.0alpha2 build logs
Julien Malik
julien.malik at c-s.fr
Tue Jun 28 04:27:19 EDT 2011
Hello
Thanks to all for your answers.
To avoid disturbing the disc alpha release process, we will change the
otb install script so that it uses the otb packages built with the
standard distribution packages (gdal 1.6).
In the meantime, I'll change our patch to fit Even's changeset, and
propose it for inclusion in the ubuntugis gdal package.
If it is accepted, we will be able to switch the OTB package to the
ubuntugis-enabled one (we have one PPA for each version).
Regards,
Julien
Le 27/06/2011 23:50, Hamish a écrit :
> Even wrote:
>> Well, you didn't read my previous email probably.
> (I hadn't)
>> It is upstream. See
>> http://trac.osgeo.org/gdal/ticket/4101
>> and
>> http://trac.osgeo.org/gdal/changeset/22461
> ok, so the solution would seem to be to try& convince Alan to
> get the patch backported into ubuntugis,& so fixed (well,
> sidestepped) for all, not just us.
> thanks,
> Hamish
More information about the Live-demo
