[Live-demo] write access to /usr/local/share/data/
Astrid Emde astrid.emde at wheregroup.com
Thu Mar 3 04:54:41 EST 2011
Hamish,
thaks for your data.
I will follow your suggestions and open a sandbox for the user.
Thanks Astrid
Hamish schrieb:
> Astrid wrote:
>> I am working in the gdal_quickstart at the moment and use
>> the natural_earth data.
>> For the exercises I need write access to the directory as
>> we create new data with the gdal-tools.
> Have an earlier step which copies data into a working directory, or use
> relative path names to data files on the command line (something like
> $HOME/data/ exists as a symlink to /usr/local/share/data/ I think)
> AFAIK gdal tools never edit data files in-place, they always make a new map,
> so original files stay read-only too.
>> DATA_FOLDER="/usr/local/share/data"
>> This is what is defined at the meoment in the file install_gisdata.sh:
>> chmod a+r "$DATA_FOLDER/natural_earth"    ## read the data dir
>> chmod 444  $DATA_FOLDER/natural_earth/*   ##  and all files in it
>> chmod -R +X "$DATA_FOLDER/natural_earth"  ## but keep x on directories
>> Is it ok to set :
>> chmod -R u+w "$DATA_FOLDER"     ## write the data dir
> No, use g+w if you absolutely must, then make sure the dir is owned by root.users   ... but the user shouldn't be allowed to write there at all.
>> I am fine to set write access only to the /natural_earth
>> firectory too:
>> chmod -R u+w "$DATA_FOLDER/natural_earth"    ## write the natural_earth
>> data dir
>> So the user can write to the data dir.
> No, things should be set up so user works in their own sandbox.
> thanks,
> Hamish
More information about the Live-demo mailing list
