[Live-demo] Setting up list of to-dos for GeoMoose install on
LiveDVD
Cameron Shorter
cameron.shorter at gmail.com
Thu May 26 17:04:16 EDT 2011
Bob,
I think answers to most of your questions are here:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Directory_Structure
Let us know if not, and we should find out and update our wiki.
Basically, we are following Ubuntu packaging conventions.
A few extra comments below. Hamish may correct me on some packaging
comments.
Alan, Alex may be able to help on mapserver questions.
On 26/05/11 08:26, Bob Basques wrote:
> All,
> So, did some more snooping on the DVD (my USB version), seems the
> structure of things are a little loose as to where things are planted,
> so, would these be the correct locations to use is there a preference
> of any sort:
> /usr/lib/cgi-bin/mapserv (for mapserver.cgi calling
> [_/http://localhost/cgi-bin/mapserv]/_ ? )
> /usr/lib/cgi-bin/PHP(5) (for PHP stuff, - if I get to it . . .)
> /usr/local/share/data/natural_earth/ (LiveDVD community data for
> demos, I also see them in POSTGIS under the "public" schema)
> (Question: are there community Mapserver Mapfiles for the POSTGIS
> layers or do I need to roll my own?)
Alan, Alex?
> And, for adding of GeoMoose stuff . . .
> /usr/lib/cgi-bin/<geomoose_custom service(s)> (GeoMoose specific
> services)
It seems so.
> /usr/local/share/data/geomoose_demo_county/ (Geomoose County demo data)
please use /usr/local/share/data/geomoose/demo_county if you are
providing a geomoose example.
However, it is my strong preference that you only use the natural earth
dataset for examples. We are trying to move all demos over to the
natural earth.
If you have a specific example that can't be shown with natural earth,
then please speak up.
> /usr/local/share/data/geomoose_demo_mercator/ (GeoMoose Mercator demo
> data)
ditto
> /var/www/geomoose/ (Geomoose install)
yes
> Apache Config stuff should go???
> /etc/apache2/conf.d/geomoose (pointer to geomoose apache config)
It seems so
> I think that's everything. Did I miss something?
> bobb
> >>> Hamish <hamish_b at yahoo.com> wrote:
> Alex wrote:
> > Also make sure to use the "mini" image to make a usb stick
> > there is a known bug in the full iso that may cause it not
> > boot which we haven't had a chance to fix yet.
> Hi,
> just to note two other bugs in the 4.5 release just found and
> fixed in svn (both trunk & the 4.5 release branch):
> Problem: gpsdrive Mapnik/OpenStreetMap rendering broken
> Reason: renaming of Natural Earth layers late in the rc cycle. oops
> Solution: edit ~/.gpsdrive/osm.xml and change "10m-urban-area"
> to "10m_urban_areas".
> Problem: welcome message never appears
> Reason: i18n efforts trod on copying the script to where it
> needed to be. oops
> Solution: copy ~/gisvm/desktop-conf/welcome_message.sh into
> /usr/local/share/osgeo-desktop/
> I expect those two, plus the Windows installer filename problem
> can be hand edits to the primary VM image, and a new full-build
> would not be not necessary. (I hope)
> Hamish
> ps- zygrib now has a quickstart, so we are 100% for those now.
> (copy editing requested)
> (do check out the CAPE instability [tornado/tstorm predictor] for
> the S.E.rn USA currently.. some 1000s of J/kg .. ouch)
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110527/32d82e6f/attachment.html
More information about the Live-demo
