[Live-demo] Planing Roadmap in OSGeo Trac for Live Project
Frank Gasdorf
fgdrf at users.sourceforge.net
Mon Apr 2 17:09:27 EDT 2012
Just a short answer for the moment,
With the osgeoid its possible to login and create new tickets
(http://trac.osgeo.org/osgeo/newticket) but I miss the version filed
as well, which can be administration as a combo box with the already
released versions. In addition admin section for the trac is not
accessible for everybody, means, that its possible for users with an
osgeo id to configure (add/rename versions or add milestones). I guess
because of the multi-project trac instance it could be it limited that
only osgeo admins can change something like this. One more reason to
setup a different trac/subversion pair for the osgeo live project.
Cheers
- Frank
2012/4/2 Cameron Shorter <cameron.shorter at gmail.com>:
> Issue Tracker
> Our issue tracker is hosted at OSGeo's Trac system, and you will need to
> create an OSGeo UserId before you can login and edit issues. To distinguish
> the LiveDVD project from other OSGeo projects, use the following
> conventions:
> Component field
> Set to `LiveDVD`
> Keywords
> Version: Set to base release version: eg: 5.0, 5.5 (not 5.5rc1)
> Application: Set to application with issue (use lower case): eg:
> "geoserver"
More information about the Live-demo
