[Live-demo] Planing Roadmap in OSGeo Trac for Live Project
Mon Apr 2 19:58:30 EDT 2012
Folks,
Note that we could add OSGeo Live related milestones and  versions in
the generic OSGeo trac as long as we prefixed them with live- or
something like that to make it clear where they apply.
Best regards,
On Mon, Apr 2, 2012 at 4:42 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> It's not a matter of admin access. More that those milestones would be
> confusing to anything filed on that trac instance that wasn't osgeo-live
> related, aka SAC tickets.
> We could add them or we could look into an independent trac instance.
> Someone will need to research how to export a portion of the tickets,
> and only a subdir of the svn.
> Thanks,
> Alex
> On 04/02/2012 02:09 PM, Frank Gasdorf wrote:
>> Just a short answer for the moment,
>> With the osgeoid its possible to login and create new tickets
>> (http://trac.osgeo.org/osgeo/newticket) but I miss the version filed
>> as well, which can be administration as a combo box with the already
>> released versions. In addition admin section for the trac is not
>> accessible for everybody, means, that its possible for users with an
>> osgeo id to configure (add/rename versions or add milestones). I guess
>> because of the multi-project trac instance it could be it limited that
>> only osgeo admins can change something like this. One more reason to
>> setup a different trac/subversion pair for the osgeo live project.
>> Cheers
>> - Frank
>> 2012/4/2 Cameron Shorter <cameron.shorter at gmail.com>:
>>> Issue Tracker
>>> Our issue tracker is hosted at OSGeo's Trac system, and you will need to
>>> create an OSGeo UserId before you can login and edit issues. To distinguish
>>> the LiveDVD project from other OSGeo projects, use the following
>>> conventions:
>>> Component field
>>>     Set to `LiveDVD`
>>> Keywords
>>>     Version: Set to base release version: eg: 5.0, 5.5 (not 5.5rc1)
>>>     Application: Set to application with issue (use lower case): eg:
>>> "geoserver"
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
More information about the Live-demo mailing list
