[Live-demo] GEOS image for OSGeo-Live Overview
Cameron Shorter
cameron.shorter at gmail.com
Tue Apr 3 16:21:25 EDT 2012
Martin,
Our criteria and checklist for bringing a project into OSGeo-Live are
linked from here:
http://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
We include applications which can be installed and run, and also include
descriptions of libraries from OSGeo incubated/incubating projects.
So I see the key criteria for including JTS would be:
1. Does it have a user interface?
2. Or otherwise, is it an OSGeo project?
Others from our team may wish to add further comment or suggestion to this.
On 02/04/12 09:40, Martin Davis wrote:
> Cameron,
> I'm fine with using that image (or image idea) for the GEOS image.
> I don't have a larger version - it would have to be recreated. This
> would be fairly easy to do using the JTS TestBuilder, which can export
> to PNG. But I won't have time to do that until after FOSS4G - I"m
> pretty busy beforehand!
> Are the questions about JTS at OSGeo and on OSGeo-Live two separate
> questions? 8^) I did have a short discussion with Frank in Denver
> about bringing JTS into OSGeo. I think he was concerned that it could
> not meet the acceptance criteria, such as having a wider developer
> community. But if it can be included on OSGeo-Live in spite of that,
> I'm happy for that to happen.
> HTH - Martin
> On Sun, Apr 1, 2012 at 1:38 PM, Cameron Shorter
> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
> On 02/04/12 04:02, Frank Warmerdam wrote:
> Frank, do you have suggestions for a GEOS image?
> Possibly something like this:
> http://tsusiatsoftware.net/jts/images/example-intersection.gif
> But that is already used for JTS so it might be a cop-out to
> grab it.
> Martin,
> I suspect that you would have been the original creator of the
> image Frank references above?
> Do you have any objection to it being used in conjunction with GEOS?
> Maybe we could have 2 variants on the same image, one for JTS, the
> other for GEOS?
> Do you have a larger version of the image? It needs to be 1024x768
> for osgeo docs.
> This does lead to a later question, about bringing JTS into OSGeo
> and OSGeo-Live. (We aim to include descriptions of all OSGeo
> library projects on OSGeo-Live.)
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
> Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120404/ea3b9ab1/attachment.html
More information about the Live-demo
