[Live-demo] Fwd: [OSGeo] #981: deegree fails
Cameron Shorter cameron.shorter at gmail.com
Fri Aug 3 20:21:26 PDT 2012
Johannes,
Did you see this. Of note, we have been forced to change our build
process, which likely has something to do with this failure.
Could you please have a look and update the issue, or discuss the issue
on live-demo at lists.osgeo.org or irc://freenode.net#osgeolive
-------- Original Message --------
Subject: 	[Live-demo] [OSGeo] #981: deegree fails
Date: 	Sat, 04 Aug 2012 01:26:14 -0000
Reply-To: 	warmerdam at pobox.com
To: 	undisclosed-recipients:;
#981: deegree fails
  Reporter:  darkblueb  |       Owner:  live-demo@…
      Type:  defect     |      Status:  new
  Priority:  critical   |   Milestone:  OSGeoLive6.0RC1
Component:  LiveDVD    |    Keywords:  beta8, chroot build method
  after installing using beta8-alt
  deegree does not start..
  manually executing the start script line by line shows
  dbb at osgeolive:~$ export DEEGREE_WORKSPACE_ROOT="/usr/local/share/deegree"
  dbb at osgeolive:~$ DEE_DIR="/usr/local/lib/deegree-webservices-3.2-pre9"
  dbb at osgeolive:~$ cd $DEE_DIR
  dbb at osgeolive:/usr/local/lib/deegree-webservices-3.2-pre9$
  ./bin/catalina.sh start
  Using CATALINA_BASE:   /usr/local/lib/deegree-webservices-3.2-pre9
  Using CATALINA_HOME:   /usr/local/lib/deegree-webservices-3.2-pre9
  Using CATALINA_TMPDIR: /usr/local/lib/deegree-webservices-3.2-pre9/temp
  Using JRE_HOME:        /usr
  Using CLASSPATH:       /usr/local/lib/deegree-
  webservices-3.2-pre9/bin/bootstrap.jar
  touch: cannot touch `/usr/local/lib/deegree-
  webservices-3.2-pre9/logs/catalina.out': No such file or directory
  ./bin/catalina.sh: 338: ./bin/catalina.sh: cannot create /usr/local/lib
  /deegree-webservices-3.2-pre9/logs/catalina.out: Directory nonexistent
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/981>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org
http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120804/7bae8068/attachment-0001.html>
More information about the Live-demo mailing list
