[Live-demo] [OSGeo] #983: chroot build method: postgis fails to create databases
OSGeo trac_osgeo at osgeo.org
Sun Aug 5 08:38:30 PDT 2012
 Reporter:  kalxas    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive6.0RC1
Component:  LiveDVD   |    Keywords:  6.0
 as per http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-mini-
 build8731-log.tar.gz
 Processing triggers for menu ...
 ALTER ROLE
 createdb: database creation failed: ERROR:  new encoding (UTF8) is
 incompatible with the encoding of the template database (SQL_ASCII)
 HINT:  Use the same encoding as in the template database, or use template0
 as template.
 createlang: could not connect to database template_postgis: FATAL:
 database "template_postgis" does not exist
 UPDATE 0
 psql: FATAL:  database "template_postgis" does not exist
 Finished: ./install_postgis.sh
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/983>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
