[Live-demo] Chroot customization status
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Aug 7 01:52:55 PDT 2012
On 08/07/2012 11:14 AM, Hamish wrote:
> Alex wrote:
>> I figured out setting the username,
>> hostname, password and boot kernel.
> for posterity & the benefit of those searching the archives, can you
> briefly state what the trick was?
>> We can handle newer kernels but it's a little tricky so its
>> hard coded to the default kernel from Xubuntu iso for now.
> what's the issue? how does it work that makes that needed?
> (can you explain a little about what initrd is and how to go about
> changing and rebuilding it)
>> The fixes are in the build_chroot_debug.sh and need to be
>> ported over to build_chroot.sh once verified.
> once done (which I think has already happened), & if no longer needed,
> to avoid confusion can you delete the clone?
> thanks,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Hamish, the clone debug script will be needed in the future in order to
test single packages. Plus we are still using it.
Cheers,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo
