[Live-demo] [OSGeo] #988: chroot build method: autologin failure due to rasdaman
    OSGeo
    trac_osgeo at osgeo.org
    Thu Aug  9 06:29:55 PDT 2012
 Reporter:  kalxas    |       Owner:  kalxas
     Type:  defect    |      Status:  assigned
 Priority:  critical  |   Milestone:  OSGeoLive6.0RC1
Component:  LiveDVD   |    Keywords:  6.0
Comment(by hamish):
 it can't just be due to 'user' was owning files outside of /home/user, in
 6.0beta9 if you run:
 sudo su
 cd /
 find / -uid 1000
 ('user' is UID 999 in the live-iso)
 you get 14000 files! including /usr, /var, and /etc/ld.so.conf.d/
 /opt/gvSIG, Kosmo, qgis_mapserver, /usr/local/share/gisvm (!), web2py, and
 geonetwork seem to be the major offenders. probably because they extract
 tarballs to / as the superuser without using the --no-same-owner flag to
 reset the owner to root. (if so, it's an easy fix)
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/988#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
