[Live-demo] [OSGeo] #991: chroot build method: mapfish does not start
OSGeo
trac_osgeo at osgeo.org
Fri Aug 10 13:25:03 PDT 2012
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive6.0RC1
Component: LiveDVD | Keywords: 6.0 beta9
Comment(by hamish):
rc.local fix didn't take. re-fixed in r8928.
even with the groups updated I still get an Internal Server Error when I
go to the mapfish example listed in the quickstart.
same "FATAL: database "v2.2_mapfishsample" does not exist" error as
reported earlier.
/var/log/apache2/error.log says:
Fri Aug 10 08:52:19 2012] [notice] Graceful restart requested, doing
restart
apache2: Could not reliably determine the server's fully qualified domain
name, using 127.0.1.1 for ServerName
[Fri Aug 10 08:52:22 2012] [warn] mod_wsgi: Compiled for Python/2.7.2+.
[Fri Aug 10 08:52:22 2012] [warn] mod_wsgi: Runtime using Python/2.7.3.
[Fri Aug 10 08:52:22 2012] [notice] Apache/2.2.22 (Ubuntu) mod_fcgid/2.3.6
PHP/5.3.10-1ubuntu3.2 with Suhosin-Patch mod_wsgi/3.3 Python/2.7.3
configured -- resuming normal operations
[Fri Aug 10 08:52:25 2012] [notice] Graceful restart requested, doing
restart
[Fri Aug 10 08:52:26 2012] [warn] mod_wsgi: Compiled for Python/2.7.2+.
[Fri Aug 10 08:52:26 2012] [warn] mod_wsgi: Runtime using Python/2.7.3.
[Fri Aug 10 08:52:26 2012] [notice] Apache/2.2.22 (Ubuntu) mod_fcgid/2.3.6
[Fri Aug 10 20:05:59 2012] [warn] mod_wsgi: Compiled for Python/2.7.2+.
[Fri Aug 10 20:05:59 2012] [warn] mod_wsgi: Runtime using Python/2.7.3.
[Fri Aug 10 20:05:59 2012] [notice] Apache/2.2.22 (Ubuntu) mod_fcgid/2.3.6
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] mod_wsgi (pid=3265):
Target WSGI script
'/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi' cannot
be loaded as Python module.
Exception occurred processing WSGI script
'/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi'.
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] Traceback (most
recent call last):
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] File
"/usr/local/lib/mapfish/MapfishSample/buildout/parts/modwsgi/wsgi", line
46, in <module>
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] application =
loadapp("config:" + configfile)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/loadwsgi.py",
line 203, in loadapp
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] return
loadobj(APP, uri, name=name, **kw)
line 224, in loadobj
context.create()
line 617, in create
self.object_type.invoke(self)
line 109, in invoke
fix_call(context.object, context.global_conf, **context.local_conf)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/PasteDeploy-1.3.4-py2.7.egg/paste/deploy/util/fixtypeerror.py",
line 57, in fix_call
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] val =
callable(*args, **kw)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/middleware.py",
line 37, in make_app
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] config =
load_environment(global_conf, app_conf)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/config/environment.py",
line 49, in load_environment
init_model(engine)
"/usr/local/lib/mapfish/MapfishSample/mapfishsample/model/__init__.py",
line 16, in init_model
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] class Poi(Base,
GeometryTableMixIn):
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/ext/declarative.py",
line 1165, in __init__
_as_declarative(cls, classname, cls.__dict__)
line 1064, in _as_declarative
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] **table_kw)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/schema.py",
line 265, in __new__
table._init(name, metadata, *args, **kw)
line 324, in _init
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] self,
include_columns
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/engine/base.py",
line 2262, in run_callable
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] conn =
self.contextual_connect()
line 2328, in contextual_connect
self.pool.connect(),
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/pool.py",
line 209, in connect
_ConnectionFairy(self).checkout()
line 370, in __init__
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] rec =
self._connection_record = pool._do_get()
line 696, in _do_get
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] con =
self._create_connection()
line 174, in _create_connection
_ConnectionRecord(self)
line 255, in __init__
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] self.connection
= self.__connect()
line 315, in __connect
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] connection =
self.__pool._creator()
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/engine/strategies.py",
line 80, in connect
dialect.connect(*cargs, **cparams)
"/usr/local/lib/mapfish/MapfishSample/buildout/eggs/SQLAlchemy-0.7.2-py2.7-linux-i686.egg/sqlalchemy/engine/default.py",
line 275, in connect
self.dbapi.connect(*cargs, **cparams)
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] OperationalError:
(OperationalError) FATAL: database "v2.2_mapfishsample" does not exist
[Fri Aug 10 20:09:44 2012] [error] [client 127.0.0.1] None None
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/991#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
