[Live-demo] errors from the latest build log
Hamish
hamish_b at yahoo.com
Sun Aug 12 02:14:31 PDT 2012
a quick grep through the latest build log (r8980) found the following problems.
there may be more, I haven't looked through it from end to end.
http://aiolos.survey.ntua.gr/gisvm/dev/
osgeo-live-mini-6.0build8980-log.tar.gz
mysql
Restarting mysql..
.. MySQL admin name is <debian-sys-maint>. (see /etc/mysql/debian.cnf)
4722:ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
ushahidi
Restarting mysql..
7075:ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
(see ticket #969)
After clicking "Let's get started" there's an error at the top:
* The imap extension could not be loaded
and can go no further.
QGIS
Searching for owslib
Reading http://pypi.python.org/simple/owslib/
Reading http://trac.gispython.org/projects/PCL/wiki/OwsLib
Reading https://geopython.github.com/OWSLib
Download error on https://geopython.github.com/OWSLib: [Errno 111] Connection refused -- Some packages may not be found!
Reading https://sourceforge.net/apps/trac/owslib
Reading https://sourceforge.net/apps/trac/owslib/
Best match: OWSLib 0.5.1
Downloading http://pypi.python.org/packages/source/O/OWSLib/OWSLib-0.5.1.tar.gz#md5=d4cbfc43de32ffcf39cb358b280b0153
Processing OWSLib-0.5.1.tar.gz
-- I think this can be ignored & it tries and finds another source for the file
Build finished. The HTML pages are in _build/html.
--2012-08-12 00:37:02-- http://download.osgeo.org/livedvd/data/qgis/qgis-plugins-6.0.tar.gz
Resolving download.osgeo.org (download.osgeo.org)... failed: Name or service not known.
wget: unable to resolve host address `download.osgeo.org'
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Finished installing QGIS 1.8.0-1.
-- There seems to be some DNS trouble on the build server. It also has problems finding
sourceforge.net for openjump and Ubuntu's user manual pdf when trying it manually
works fine.
10816:createdb: database creation failed: ERROR: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII)
-- we think we've got a handle on this one now, the template needs to be created as UTF8
in install_postgis.sh
10693:/tmp/easy_install-Gw36Py/Shapely-1.2.8/setup.py:10: Warning: Failed to import distribute_setup, continuing without distribute.
19103:create_db.sh: PostgreSQL database generation...\ccreate_db.sh: rasdaman dictionnary initialization...\cUsing error text file: /usr/local/rasdaman/share/rasdaman//errtxts
19107:Using error text file: /usr/local/rasdaman/share/rasdaman//errtxts
19118:Using error text file: /usr/local/rasdaman/share/rasdaman//errtxts
19143:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:3: ERROR: table "ps_multipoint" does not exist
19144:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:4: ERROR: table "ps_multisolid" does not exist
19145:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:5: ERROR: table "ps_multisurface" does not exist
19146:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:6: ERROR: table "ps_multicurve" does not exist
19147:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:9: ERROR: table "ps_crsdetails" does not exist
19148:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:10: ERROR: table "ps_descriptions" does not exist
19149:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:11: ERROR: table "ps_crsset" does not exist
19150:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:12: ERROR: table "ps_nullset" does not exist
19151:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:13: ERROR: table "ps_interpolationset" does not exist
19152:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:14: ERROR: table "ps_range" does not exist
19153:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:15: ERROR: table "ps_domain" does not exist
19154:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:16: ERROR: table "ps_celldomain" does not exist
19155:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:17: ERROR: table "ps_coverage" does not exist
19156:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:18: ERROR: table "ps_format" does not exist
19157:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:19: ERROR: table "ps_crs" does not exist
19158:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:20: ERROR: table "ps_nullresistance" does not exist
19159:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:21: ERROR: table "ps_interpolationtype" does not exist
19160:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:22: ERROR: table "ps_datatype" does not exist
19161:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:23: ERROR: table "ps_axistype" does not exist
19162:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:24: ERROR: table "ps_uom" does not exist
19163:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:25: ERROR: table "ps_dbupdates" does not exist
19164:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:27: ERROR: table "ps_styles" does not exist
19165:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:28: ERROR: table "ps_pyramidlevels" does not exist
19166:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:29: ERROR: table "ps_servicelayer" does not exist
19167:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:30: ERROR: table "ps_services" does not exist
19168:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:31: ERROR: table "ps_layers" does not exist
gvSIG
21804:E: Unable to locate package gvsig
-- probably harmless, but should be cleaned up
i18n
23908:/usr/local/share/gisvm/doc/fr/overview/osgearth_overview.rst:55: ERROR: Unknown target name: "esri".
openjump
mv: cannot stat `openjump.desktop': No such file or directory
-- DNS lookup of sf.net failed, program didn't get installed.
Remastering the dvd
df: Warning: cannot read table of mounted file systems
cryptsetup: WARNING: could not determine root device from /etc/fstab
cat: /proc/cmdline: No such file or directory
/tmp/mkinitramfs_UbYVsu/scripts/casper-bottom/48xubuntu_maybe_ubiquity: 6: .: Can't open /scripts/casper-functions
sed: can't read extract-cd/.disk/info: No such file or directory
setup.sh
3119:invoke-rc.d: initscript apparmor, action "start" failed.
3123:invoke-rc.d: initscript apparmor, action "reload" failed.
GeoMajas
5290:GeoMajas FIXME: *** Do not use 777 if at all possible. ***
OpenJump/QGIS/Ubuntu user manual
5726:Resolving sourceforge.net (sourceforge.net)... failed: Name or service not known.
8462:Resolving download.osgeo.org (download.osgeo.org)... failed: Name or service not known.
31424:Resolving files.ubuntu-manual.org (files.ubuntu-manual.org)... failed: Name or service not known.
-- DNS trouble on the build server?
thanks,
Hamish
More information about the Live-demo
