[Live-demo] [OSGeo] #997: QGIS quickstart requires > 2G RAM
    OSGeo
    trac_osgeo at osgeo.org
    Sat Aug 18 06:30:37 PDT 2012
 Reporter:  camerons  |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  minor     |   Milestone:  OSGeoLive6.5
Component:  LiveDVD   |    Keywords:  6.5, qgis
Comment(by micha):
 A bit more information:
 The G_Malloc error does not happen in an '''installed''' VirtualBox VM,
 even with only 1 GB RAM. The error comes up only when running as a Live
 DVD system.
 NVIZ is already part of the GRASS quickstart, and under GRASS it works
 with 1GB even in a LiveDVD system. Just to be on the safe side, it might
 be best to replace the NVIZ example in QGIS with some other GRASS module.
 Perhaps r.param.scale ? (not shown in the GRASS quickstart). THis seems to
 work quite well with only 1GB, both in an installed VM and a Live system
 (provided you set the region to the elevation at PERMANENT raster first)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/997#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
