[Live-demo] [OSGeo] #998: R demo portion fails
    OSGeo
    trac_osgeo at osgeo.org
    Sun Aug 19 00:13:36 PDT 2012
 Reporter:  darkblueb  |       Owner:  live-demo@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  OSGeoLive6.5
Component:  LiveDVD    |    Keywords:  R
 due to a missing dependency ''maps''
 > library(gstat)
 > demo(wind)
         demo(wind)
 Type  <Return>   to start :
 > #pdf("wind.pdf")
 > library(gstat)
 > library(rgdal)
 Geospatial Data Abstraction Library extensions to R successfully loaded
 Loaded GDAL runtime: GDAL 1.9.1, released 2012/05/15
 Path to GDAL shared files: /usr/share/gdal/1.9
 Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009, [PJ_VERSION: 470]
 Path to PROJ.4 shared files: (autodetected)
 > library(maptools)
 Loading required package: foreign
 Checking rgeos availability: FALSE
         Note: when rgeos is not available, polygon geometry
 computations in maptools depend on gpclib,
         which has a restricted licence. It is disabled by default;
         to enable gpclib, type gpclibPermit()
 > # load wind data, run test:
 > example(wind)
 wind> data(wind)
 wind> summary(wind)
       year          month             day             RPT
  Min.   :61.0   Min.   : 1.000   Min.   : 1.00   Min.   : 0.67
  1st Qu.:65.0   1st Qu.: 4.000   1st Qu.: 8.00   1st Qu.: 8.12
  Median :69.5   Median : 7.000   Median :16.00   Median :11.71
  Mean   :69.5   Mean   : 6.523   Mean   :15.73   Mean   :12.36
  3rd Qu.:74.0   3rd Qu.:10.000   3rd Qu.:23.00   3rd Qu.:15.92
  Max.   :78.0   Max.   :12.000   Max.   :31.00   Max.   :35.80
       VAL             ROS             KIL              SHA
  Min.   : 0.21   Min.   : 1.50   Min.   : 0.000   Min.   : 0.13
  1st Qu.: 6.67   1st Qu.: 8.00   1st Qu.: 3.580   1st Qu.: 6.75
  Median :10.17   Median :10.92   Median : 5.750   Median : 9.96
  Mean   :10.65   Mean   :11.66   Mean   : 6.306   Mean   :10.46
  3rd Qu.:14.04   3rd Qu.:14.67   3rd Qu.: 8.420   3rd Qu.:13.54
  Max.   :33.37   Max.   :33.84   Max.   :28.460   Max.   :37.54
       BIR              DUB              CLA              MUL
  Min.   : 0.000   Min.   : 0.000   Min.   : 0.000   Min.   : 0.000
  1st Qu.: 4.000   1st Qu.: 6.000   1st Qu.: 5.090   1st Qu.: 5.370
  Median : 6.830   Median : 9.210   Median : 8.080   Median : 8.170
  Mean   : 7.092   Mean   : 9.797   Mean   : 8.494   Mean   : 8.496
  3rd Qu.: 9.670   3rd Qu.:12.960   3rd Qu.:11.420   3rd Qu.:11.210
  Max.   :26.160   Max.   :30.370   Max.   :31.080   Max.   :25.880
       CLO              BEL             MAL
  Min.   : 0.040   Min.   : 0.13   Min.   : 0.67
  1st Qu.: 5.330   1st Qu.: 8.71   1st Qu.:10.71
  Median : 8.290   Median :12.50   Median :15.00
  Mean   : 8.707   Mean   :13.12   Mean   :15.60
  3rd Qu.:11.630   3rd Qu.:16.88   3rd Qu.:19.83
  Max.   :28.210   Max.   :42.38   Max.   :42.54
 wind> wind.loc
          Station Code       Latitude     Longitude MeanWind
 1       Valentia  VAL        51d56'N       10d15'W     5.48
 2      Belmullet  BEL        54d14'N       10d00'W     6.75
 3    Claremorris  CLA        53d43'N        8d59'W     4.32
 4        Shannon  SHA        52d42'N        8d55'W     5.38
 5  Roche's Point  RPT        51d48'N        8d15'W     6.36
 6           Birr  BIR        53d05'N        7d53'W     3.65
 7      Mullingar  MUL        53d32'N        7d22'W     4.38
 8     Malin Head  MAL        55d22'N        7d20'W     8.03
 9       Kilkenny  KIL        52d40'N        7d16'W     3.25
 10        Clones  CLO        54d11'N        7d14'W     4.48
 11        Dublin  DUB        53d26'N        6d15'W     5.05
 12       Roslare  ROS 52d16'56.791"N 6d21'25.056"W     6.00
 wind> wind.loc$y =
 as.numeric(char2dms(as.character(wind.loc[["Latitude"]])))
 wind> wind.loc$x =
 as.numeric(char2dms(as.character(wind.loc[["Longitude"]])))
 wind> coordinates(wind.loc) = ~x+y
 wind> # fig 1:
 wind> ## No test:
 wind>  if (require(mapdata)) {
 wind+    map("worldHires", xlim = c(-11,-5.4), ylim = c(51,55.5))
 wind+    plot(wind.loc, add=TRUE, pch=16)
 wind+    text(coordinates(wind.loc), pos=1, label=wind.loc$Station)
 wind+  }
 Loading required package: mapdata
 wind> ## End(No test)
 wind> wind$time = ISOdate(wind$year+1900, wind$month, wind$day)
 wind> # time series of e.g. Dublin data:
 wind> plot(DUB~time, wind, type= 'l', ylab = "windspeed (knots)", main =
 "Dublin")
 Hit <Return> to see next plot:
 wind> # fig 2:
 wind> #wind = wind[!(wind$month == 2 & wind$day == 29),]
 wind> wind$jday = as.numeric(format(wind$time, '%j'))
 wind> windsqrt = sqrt(0.5148 * as.matrix(wind[4:15]))
 wind> Jday = 1:366
 wind> windsqrt = windsqrt - mean(windsqrt)
 wind> daymeans = sapply(split(windsqrt, wind$jday), mean)
 wind> plot(daymeans ~ Jday)
 wind> lines(lowess(daymeans ~ Jday, f = 0.1))
 wind> # subtract the trend:
 wind> meanwind = lowess(daymeans ~ Jday, f = 0.1)$y[wind$jday]
 wind> velocity = apply(windsqrt, 2, function(x) { x - meanwind })
 wind> # match order of columns in wind to Code in wind.loc:
 wind> pts = coordinates(wind.loc[match(names(wind[4:15]),
 wind.loc$Code),])
 wind> # fig 3, but not really yet...
 wind> dists = spDists(pts, longlat=TRUE)
 wind> corv = cor(velocity)
 wind> sel = !(as.vector(dists) == 0)
 wind> plot(as.vector(corv[sel]) ~ as.vector(dists[sel]),
 wind+   xlim = c(0,500), ylim = c(.4, 1), xlab = "distance (km.)",
 wind+   ylab = "correlation")
 wind> # plots all points twice, ignores zero distance
 wind>
 wind> # now really get fig 3:
 wind> ros = rownames(corv) == "ROS"
 wind> dists.nr = dists[!ros,!ros]
 wind> corv.nr = corv[!ros,!ros]
 wind> sel = !(as.vector(dists.nr) == 0)
 wind> plot(as.vector(corv.nr[sel]) ~ as.vector(dists.nr[sel]), pch = 3,
 wind> # add outlier:
 wind> points(corv[ros,!ros] ~ dists[ros,!ros], pch=16, cex=.5)
 wind> xdiscr = 1:500
 wind> # add correlation model:
 wind> lines(xdiscr, .968 * exp(- .00134 * xdiscr))
 > m = map2SpatialLines(
 +       map("worldHires", xlim = c(-11,-5.4), ylim = c(51,55.5), plot=F))
 Loading required package: maps
 Error in cbind(map$x, map$y) : could not find function "map"
 In addition: Warning messages:
 1: In library(package, lib.loc = lib.loc, character.only = TRUE,
 logical.return = TRUE,  :
   there is no package called ‘mapdata’
 2: In library(package, lib.loc = lib.loc, character.only = TRUE,
   there is no package called ‘maps’
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/998>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
