[Live-demo] [OSGeo] #1001: 6.0 Failed to install to hard drive
OSGeo
trac_osgeo at osgeo.org
Thu Aug 30 02:10:01 PDT 2012
Reporter: Aborrell | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive6.0Final
Component: LiveDVD | Keywords: ubiquity, 6.0
Comment(by kalxas):
All the iso testing I did (including the final build) was based on the
mini iso, which I can confirm that works ok during installation.
Alex, can you please create a "OSGeoLive6.0.1" Milestone in Trac to
assign?
Thanks,
Angelos
Replying to [comment:3 hamish]:
> Hi,
> I can reproduce this with the 6.0 full iso, trying to install to a VM
image drive with kvm/qemu. Also if I press the any key at bootup and
select "Install Xubuntu" from the old boot menu, it just ignores that and
boots up as the regular user.
> The exact timing of when we did the test installs slips my mind, but
perhaps our last minute neutering of ubiquity caused some collateral
damage? And yet Alex was able to create a VM from an iso, right? Was the
mini used for that? If so, maybe it was the remastering of the full iso
which caused the trouble? The error message in the above ML post (& I get
the same one) had something to do about reading the filesystem size.
> As a start, to test the neutered-ubiquity at start we can manually undo
the change to /etc/init/ubiquity.conf while booted in the iso. But before
trying that I'll try installing from a final mini.iso.
> Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1001#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
