[Live-demo] 5.5 Beta 2 Status
Alex Mandel tech_dev at wildintellect.com
Sat Feb 4 14:09:23 EST 2012
Done, http://live.osgeo.org/dev/build
Thanks,
Alex
On 02/04/2012 05:27 AM, Angelos Tzotsos wrote:
> Thanks for the first review Hamish.
> FYI the mini iso is up too.
> Alex, can you please mirror the files to your server?
> Thanks,
> Angelos
> On Sat, Feb 4, 2012 at 7:12 AM, Hamish <hamish_b at yahoo.com> wrote:
>> Angelos wrote:
>>> Just completed the 5.5 beta2 build.
>>> Logs are here:
>>> http://aiolos.survey.ntua.gr/gisvm/5.5/
>> Hi,
>> some notes after a quick look at the log:
>> R:
>> http://cran.cnr.berkeley.edu seemed to be having a bad hair day.
>> this error took out rasdaman as collateral damage.
>> QGIS:
>> tutorial doc build failed (hopefully now fixed in svn.)
>> jef provided a new 1.7.3-2 with the qgis_mapserver patch applied, which is
>> hopefully now functional
>> again.
>> MapGuide:
>> experimental install failed; script needs to be updated for natty.
>> I've disabled it completely until that happens.
>> (fdo-core : Depends: odbcinst1debian1 (>= 2.2.11-3) but it is not
>> installable.
>> the package is now called odbcinst1debian2.)
>> this left dpkg in a broken state, run 'apt-get -f install' to fix it.
>> tip: try 'gdebi' instead of 'dpkg -i'
>> mb-system and the language packs were taken out as collateral damage by
>> this.
>> deegree:
>> I've forcibly set its tomcat to use alternate ports
>> as it was conflicting with the system's on port 8080.
>> 52n:
>> your tomcat appears ok with ports.
>> deegree & 52n:
>> if there's a way to start tomcat with an alternate
>> conf/server.xml file, we could reuse the system's
>> install, saving 200-300 megabytes of disc space
>> lost to file redundancy.
>> is it possible to launch 2-3 tomcats with diff't
>> configs from the same core installation?
>> i.e., similar to running: apache2 -f config.file
>> (AFAIU if all web apps use the same tomcat instance
>> they all are kept running blowing our RAM budget,
>> so the bigger ones need their own which can be
>> started and stopped on demand.)
>> Natural Earth data:
>>  Starting AtlasStyler...
>>  log4j:WARN No appenders could be found for logger (ResourceProvider).
>>  log4j:WARN Please initialize the log4j system properly.
>> (repeated many many times)
>> setup:
>> modern kernel headers package removal version was
>> out of date (fixed in svn; 82mb freed)
>> openjdk7:
>> don't use verbose unpacking, it swamps the build log with noise (fixed in
>> svn)
>> GeoMajas:
>> Do not use mode 777 if at all possible.
>> kosmo:
>> maptiler:
>> don't use wget for local files, just copy from local svn checkout.
>> liblas:
>> verify that 'apt-get --yes autoremove' doesn't take
>> out any innocent libraries needed by other projects.
>> mapfish:
>> (non-fatal?) problem installing Shapely
>> desktop:
>> passwords.txt and welcome message failed, I suspect
>> because /usr/local/share/gisvm/bin was a symlink
>> for this build? (??)
>> that's all for now,
>> Hamish
More information about the Live-demo mailing list
