[Live-demo] OSGeoLive 5.5 draft for background image
Brian Hamlin
maplabs at light42.com
Mon Feb 6 16:43:28 EST 2012
the ALL CAPS style is because it it a headline
(if you look at billboards and other large type applications, you may
notice that they rarely use mixed case or lower case)
I can make the change to drop the DVD part now
I am mildly against changing the case of the type for that reason
-Brian
On Feb 6, 2012, at 12:04 PM, Cameron Shorter wrote:
> Brian, thanks for that image.
> I do like the simplicity of that image you have prepared, in that
> it won't clash with any desktop logos, and I'm mildly in favour of
> it over the suggestion from Astrid. (Although I think Astrid's
> image would work well for a DVD cover).
> One minor comment, can we please change the text from:
> "OSGEO LIVE DVD v5.5" to "OSGeo-Live 5.5"
> Note:
> * The ISO will be used on USBs as well as DVDs, hence drop the DVD
> * The capitalisation is how we have been referring to OSGeo-Live in
> prior marketing
> On 07/02/12 05:24, Brian Hamlin wrote:
>> On Feb 6, 2012, at 9:32 AM, Bob Basques wrote:
>>> All,
>>> About the background image, how about cycling through a set of
>>> images, say the previous LiveDVD images in order to end at the
>>> latest version.
>>> The process could be accomplished something like this: http://
>>> www.youtube.com/watch?v=4S35wNiihDM
>>> I'm all about the user experience, so may not sit nicely with
>>> some more stoic personalities.
>>> bobb
>> Hi Bob-
>> I think ... that the disk needs to convey a sense of stability,
>> at all opportunites
>> Although there is nothing wrong with images moving at a constant
>> pace..
>> the images would have to relate to each other, and in a way that
>> could not alarm
>> a nervous new user
>> I have added the desktops from the last couple of Live's to the
>> repo just now
>> I think gisvm.desktop-conf/ has some clutter, but I will leave
>> it to all to figure out what to do with that
>> best regards
>> Brian Hamlin
>> GeoCal
>> OSGeo California Chapter
>> 415-717-4462 cell
>>> >>> Brian Hamlin <maplabs at light42.com> wrote:
>>> Hi Angelos -
>>> I also have made a background image. More choices !!
>>> gisvm/desktop-conf/osgeo_ldvd_55_1F.png
>>> best regards from California
>>> -Brian
>>> On Feb 6, 2012, at 3:59 AM, Angelos Tzotsos wrote:
>>> > Hi,
>>> > Any chance we can get this background image for beta3 later today?
>>> > On Mon, Feb 6, 2012 at 1:54 PM, Astrid Emde
>>> > <astrid.emde at wheregroup.com> wrote:
>>> > Hello Hamish,
>>> > Am 06.02.2012 03:38, schrieb Hamish:
>>> > Astrid Emde wrote:
>>> > and have a question about the background image and sleeves.
>>> > We have the FOSSGIS conference in march and are going to use
>>> > OSGeo-Live in the workshops and we will give the DVD to the
>>> > participants of the conference.
>>> > excellent, that's its purpose in life!
>>> > People from the orga team created a desktop image and are
>>> > going to create an image for the dvd cover too.
>>> > I commited the first draft of the background image to the
>>> > svn [2].
>>> > note that the graphic there says "5.0" not "5.5"
>>> > Thanks for the info. I did not notice that.
>>> > My suggestion was to make the image a bit more pale to see
>>> > the desktop links better.
>>> > in the artwork/ dir you will see background.xcf.bz2.
>>> > If you open that in GIMP and look at the layer list you'll see
>>> > a white and black overlay layer. Make one or the other visible
>>> > and adjust the opacity level to suit. (GIMP can open .gz or .bz2
>>> > directly without having to un-zip it first)
>>> > n.b.: please run 'optipng -o5 filename.png' before uploading.
>>> > For really huge .psd and .xcf image data (eg there's a 60mb image
>>> > file in there) /please/ bzip2 them before upload, or consider
>>> > another place (like flickr) and commit a text file with the link.
>>> > huge binary files clog up the Subversion DB backups!
>>> > ok, I try that out.
>>> > And sorry for blowing up the svn with the image. I will keep an
>>> eye
>>> > on this in the future.
>>> > We could take a version without the FOSSGIS logo and the
>>> > building for the official version. What do you think?
>>> > I'm mostly fine with whatever choice is made, as long as it is
>>> > not too day-glow fluorescent and the left side is not too busy
>>> > so the icons gets lost in the clutter.
>>> > Cameron:
>>> > One thing I'm going to strongly push for is that we have one
>>> > generic background image for each release, rather create a
>>> > different image for each conference.
>>> > personally I feel that each conference committee should make
>>> > it be whatever they like it to be, and a conference-themed
>>> > backdrop is a very nice touch to remember it by. If they're
>>> > paying the bill for the print run = their choice to do as they
>>> > please, not ours.. (but if 3rd parties want something custom
>>> > they'll have to contribute that work themselves of course)
>>> > I think it would be highly odd for "FOSS4G 2012 Beijing" not
>>> > to have its own backdrop image if they wanted one. Ideally
>>> > the conference committee should supply it, and we should give
>>> > them good lead time to decide on a design and prepare it (or
>>> > have it prepared).
>>> > This is because in the past, the effort required to change the
>>> > background image, rebuild the ISO, then retest everything,
>>> > turned out to be much more work that you would expect for such
>>> > a small change.
>>> > over-copying the one file:
>>> > /usr/share/xfce4/backdrops/osgeo-desktop.png
>>> > is a very simple task and does not require recertifying the
>>> > entire build from scratch. AFAIU if nothing else has changed,
>>> > the final ISO build either works or it doesn't. (with a suitable
>>> > number of fingers and toes crossed for good luck)
>>> > Would be nice to have our own background image for the FOSSGIS and
>>> > also would be great to use this image without the FOSSGIS stuff
>>> for
>>> > the official OSGeo-Live design. We could save work.
>>> > Astrid
>>> > _______________________________________________
>>> > Live-demo mailing list
>>> > Live-demo at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/live-demo
>>> > http://live.osgeo.org
>>> > http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> > Angelos Tzotsos
>>> > Remote Sensing Laboratory
>>> > National Technical University of Athens
>>> > http://users.ntua.gr/tzotsos
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo
