[Live-demo] Re: Should 52 North WPS continue to be included on OSGeo-Live?
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Feb 17 04:43:27 EST 2012
Hi Bastian,
The test that fails is based on the first page presented to the user after
starting up 52NWPS.
The page is a tester and has a predefined WPS POST XML request.
So a user sees a "Send" button. This is where the outdated WFS is located.
Pressing this send button fails.
OK, this is minor, but for a user with no WPS WFS experience, this is the
first thing he will try.
Regards,
Angelos
On Fri, Feb 17, 2012 at 9:37 AM, Bastian Schäffer
<b.schaeffer at 52north.org>wrote:
> Hi Angelos,
> yes, good idea. The external WFS is a geoserver and a default dataset is
> used.
> So my question:
> - How was the WPS tested? Leading to: Where is the request with the
> outdated WFS URL located?
> Regards,
> Bastian
> Am 17/02/2012 00:46, schrieb Angelos Tzotsos:
>  Hi Bastian and thanks for the feedback.
>> Perhaps you could use a GeoServer WFS layer from within the DVD, like
>> Zoo-Project does for its demo.
>> Regards,
>> Angelos
>> On 02/17/2012 12:58 AM, Cameron Shorter wrote:
>>> Thanks for the feedback Bastian,
>>> So we have a couple of issues here:
>>> 1. The LiveDVD is referencing an external URL, which means it won't work
>>> when offline. We aim to have the DVD work even when offline.
>>> Is it possible to make use of a locally installed URL in its place?
>>> 2. If we can't get a local URL set up, who owns the broken URL:
>>> http://giv-wps.uni-muenster.**de:8080/<http://giv-wps.uni-muenster.de:8080/>
>>> Can we either get it back online, or alternatively, find a more stable
>>> URL to replace it with?
>>> On 17/02/2012 9:23 AM, Bastian Schäffer wrote:
>>>> Hi Cameron,
>>>> Hamish is right, the "problem" is the external WFS. So, the WPS server
>>>> is fine (and has not changed). The test requests you send contain a non
>>>> working data link to an external WFS.
>>>> How do you test if some server is working?
>>>> How can we change the
>>>> Regards,
>>>> Bastian
>>>> Am 16.02.2012 um 23:04 schrieb Cameron Shorter<cameron.shorter at gmail.**
>>>> com <cameron.shorter at gmail.com>>:
>>>>  We have one week before we cut our final release of OSGeo-Live 5.5 (25
>>>>> Feb), and the 52 North WPS is the only application left which doesn't work.
>>>>> If we can't get it working in the next couple of days, we are going to have
>>>>> to remove it from the next osgeolive release.
>>>>> As yet, we haven't been able to connect with anyone from 52 North to
>>>>> discuss this.
>>>>> Can you please:
>>>>> 1. ASAP: Send a response to this email, confirming that someone in 52N
>>>>> has received this email.
>>>>> 2. Within 24 hours: Note whether you wish 52 North WPS to be included
>>>>> on the next OSGeo-Live release.
>>>>> 3. Within 3 days: Assuming we should keep 52N WPS, help us debug the
>>>>> issue and find a resolution.
>>>>> We have an issue description here:
>>>>> https://trac.osgeo.org/osgeo/**ticket/859<https://trac.osgeo.org/osgeo/ticket/859>
>>>>> You can usually find one of our osgeolive developers online at: irc://
>>>>> freenode.net#osgeolive
>>>>> And our email list is: live-demo at lists.osgeo.org
>>>>> Cameron Shorter
>>>>> Geospatial Solutions Manager
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
> Dr. Bastian Schäffer
> 52° North Initiative for Geospatial Open Source Software GmbH
> Martin-Luther-King-Weg 24
> Fon: +49-(0)-251–396371-41  Fax: +49-(0)-251–396371-11
> email: schaeffer at 52North.org
> 52North-site: http://www.52North.org
> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
> Local Court Muenster HRB 10849
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120217/6e2bec05/attachment.html
More information about the Live-demo mailing list
