[Live-demo] Re: Booting from OSGEOLive USB flash drive
activityworkshop
mail at activityworkshop.net
Mon Feb 20 15:20:43 EST 2012
Hi all,
Thanks for the tips. I downloaded an Ubuntu 11.10 image and burned it
to CD-RW; from there I was able to use its startup disk creator to put
the osgeo 5.5-mini-beta4 iso onto the USB stick. This time the stick
booted on one of the two computers (the second still refused, don't know
why).
So here's what I found:
- I recommend you put some note in the wiki page about requiring an
Ubuntu startup disk creator > 11.04 or whatever the minimum is.
- It booted fine and seemed to run fine during my short test. Looks
good too!
- Sun java is properly installed (I was expecting to have to test openjdk)
- Start icons for Prune are in the right places (thanks!)
- Prune seems to run fine, version 12 as expected
- I had a funny keyboard issue, where it seemed to think that my "Fn"
key was pressed down. So pressing "j" gave me a 1, and pressing Fn+"j"
(which should give a "1") gave me a j. Very weird, but it turns out
this laptop keyboard has a "NumLock" feature which I've never used
before! Didn't even know it had one. Pressing Fn+F11 turned the
numlock off again and then I could type normally. Obviously not an
osgeo bug but I'll mention it here in case it confuses somebody else!
- When I tried to shut down, first it did nothing, then second time it
complained that "Session manager must be in idle state when requesting a
shutdown." I guess it was stuck trying the first request. Couldn't log
off either, for the same reason. I've reproduced this, no clue what
it's about, but again I presume it's not an osgeo problem.
- If you're stuck for space, have you thought about removing the "Games"
directory? Maybe a controversial suggestion but maybe it would save a
few vital MB...
Cheers,
activityworkshop
More information about the Live-demo
