[Live-demo] OpenJDK Only for LiveDVD 5.5?
Jody Garnett
jody.garnett at gmail.com
Mon Jan 2 21:29:17 EST 2012
> Questions for Geotools developers:
> 1. Do geotools based applications work on OpenJDK now?
Not sure; even if they did without a build box configured with OpenJDK to ensure the library works in that environment it would not be considered a supported platform for production use. I always figure "demo" is almost more important then production use as it is a first impression.
By the same token I would not recommend projects based on GeoTools go live on OpenJDK without appropriate testing.
Perhaps the Geomajas guys could stand up a build box with OpenJDK?
> 2. Is it possible to migrate geotools based applications to OpenJDK?
Yes; would required volunteer time; hardware to run a nightly build with that configuration and so on. I recently lost two weeks to a build box at my current work site that was incorrectly configured to use OpenJDK rather than Java 6.
> 3. Can such migration happen before Feb 2012 (for OSGeo-Live 5.5)?
> We can help with testing packaged applications, but are looking for guidance from projects on where we should be focusing our energy.
I do not think so; we would need hardware in place now.
Our developers are an even split between mac, linux and windows environments. As I understand it mac OpenJDK is not ready yet (with no sign of arrival); windows is troubled.
I would wait for OpenJDK Java 7 to be released; and then set up a build box at that time.
Jody
> On 31/12/11 19:34, Jody Garnett wrote:
> > An easy one is to add the extensions into libs/ext and then run uDig without its "jre" folder so it uses the system default.
> > Geosolutions (i.e. Simone or Andrea) is the best point of contact with respect to compatibility with OpenJDK. Personally I was not going to bother until Java 7 or Java 8.
> > You could also try talking to Andrea Antonello who at least uses Linux and may be able to test?
> > If you want you can also contact me officially as "GeoTools Officer" and I will take the question to the geotools-devel email list for you. However I expect I need a more than "Open JDK" (this page for example does not give me much to work from http://openjdk.java.net/install/).
> > Jody Garnett
> > On Friday, 30 December 2011 at 9:02 PM, Cameron Shorter wrote:
> > > Jody and others,
> > > Do you know if anyone has tested the viability of using OpenJDK with JAI/ImageIO/ImageIO-EXT (with the geotools based applications)?
> > > What would be involved in testing this? Who would know how?
> > > On 30/12/11 20:29, Jody Garnett wrote:
> > > > Need to check out how well or poorly OpenJDK does with the JAI / ImageIO / ImageIO-EXT combo for geotools based apps.
> > > > Jody Garnett
> > > > On Friday, 30 December 2011 at 6:48 PM, Brian Hamlin wrote:
> > > > > jsanz tells me that GeoNetwork is also running well under OpenJDK for
> > > > > him
> > > > > let this thread be an entrypoint for Java-app contacts to express their
> > > > > enthusiasm, dismay, pain, resignation or otherwise on the adaptation
> > > > > of an OpenJDK-only LiveDVD release
> > > > > best regards from Berkeley, California
> > > > > Brian Hamlin
> > > > > GeoCal
> > > > > OSGeo California Chapter
> > > > > 415-717-4462 cell
> > > > > _______________________________________________
> > > > > Live-demo mailing list
> > > > > Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> > > > > http://lists.osgeo.org/mailman/listinfo/live-demo
> > > > > http://live.osgeo.org
> > > > > http://wiki.osgeo.org/wiki/Live_GIS_Disc
> > > > _______________________________________________ Live-demo mailing list Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org) http://lists.osgeo.org/mailman/listinfo/live-demo http://live.osgeo.org http://wiki.osgeo.org/wiki/Live_GIS_Disc
> > > -- Cameron Shorter Geospatial Director Tel: +61 (0)2 8570 5050 Mob: +61 (0)419 142 254 Think Globally, Fix Locally Geospatial Solutions enhanced with Open Standards and Open Source http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120103/e7e3f069/attachment.html
More information about the Live-demo
