[Live-demo] OpenJDK Only for LiveDVD 5.5?
Jorge Gaspar Sanz Salinas
jsanz at osgeo.org
Tue Jan 3 16:48:33 EST 2012
On 3 January 2012 21:28, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Andre, Even, Jody,
> Thank you for your insights.
> Based on your advice, it sounds like it will be unwise to try to migrate all
> java based OSGeo applications to OpenJDK by our OSGeo-Live5.5 release due in
> March 2012.
> As such, I propose that Sun Java be included on OSGeo-Live5.5.
> I'm hopeful that we can find enough space to include OpenJDK, (ideally
> version 7) on this and future OSGeo-Live releases, and start moving all
> applications across to OpenJDK as soon as they are available. This will mean
> that the OSGeo-Live community can be drawn upon to help with testing which
> hopefully can be seen as a positive for java projects.
> Does this sound reasonable?
(I remove cc to geoserver-devel to not cross post an OSGeo Live specific topic)
Yes it sounds reasonable for me.
We can't force the change right now. Having both VMs on this 5.5 or
(better IMHO) next release would be great, so projects can gradually
move to OpenJDK on mid term seems the best approach.
Anyway I think is a good thing to try to move to a completely free (as
in freedom) Java Virtual Machine now that we have OpenJDK more or less
ready to be used, at least for testing purposes. OSGeo Live is BTW a
testing/demoing environment so is OK to me even if it's not on the
perfect performance configuration.
Cheers
> Alex, it would be great if you could start the build process so that we can
> determine whether we can find sufficient space to include 2 versions of java
> on OSGeo-Live.
> On 03/01/12 13:29, Jody Garnett wrote:
> Questions for Geotools developers:
> 1. Do geotools based applications work on OpenJDK now?
> Not sure; even if they did without a build box configured with OpenJDK to
> ensure the library works in that environment it would not be considered a
> supported platform for production use. I always figure "demo" is almost more
> important then production use as it is a first impression.
> By the same token I would not recommend projects based on GeoTools go live
> on OpenJDK without appropriate testing.
> Perhaps the Geomajas guys could stand up a build box with OpenJDK?
> 2. Is it possible to migrate geotools based applications to OpenJDK?
> Yes; would required volunteer time; hardware to run a nightly build with
> that configuration and so on. I recently lost two weeks to a build box at my
> current work site that was incorrectly configured to use OpenJDK rather than
> Java 6.
> 3. Can such migration happen before Feb 2012 (for OSGeo-Live 5.5)?
> We can help with testing packaged applications, but are looking for guidance
> from projects on where we should be focusing our energy.
> I do not think so; we would need hardware in place now.
> Our developers are an even split between mac, linux and windows
> environments. As I understand it mac OpenJDK is not ready yet (with no sign
> of arrival); windows is troubled.
> I would wait for OpenJDK Java 7 to be released; and then set up a build box
> at that time.
> Jody
> On 31/12/11 19:34, Jody Garnett wrote:
> An easy one is to add the extensions into libs/ext and then run uDig without
> its "jre" folder so it uses the system default.
> Geosolutions (i.e. Simone or Andrea) is the best point of contact with
> respect to compatibility with OpenJDK. Personally I was not going to bother
> until Java 7 or Java 8.
> You could also try talking to Andrea Antonello who at least uses Linux and
> may be able to test?
> If you want you can also contact me officially as "GeoTools Officer" and I
> will take the question to the geotools-devel email list for you. However I
> expect I need a more than "Open JDK" (this page for example does not give me
> much to work from http://openjdk.java.net/install/).
> Jody Garnett
> On Friday, 30 December 2011 at 9:02 PM, Cameron Shorter wrote:
> Jody and others,
> Do you know if anyone has tested the viability of using OpenJDK with
> JAI/ImageIO/ImageIO-EXT (with the geotools based applications)?
> What would be involved in testing this? Who would know how?
> On 30/12/11 20:29, Jody Garnett wrote:
> Need to check out how well or poorly OpenJDK does with the JAI / ImageIO /
> ImageIO-EXT combo for geotools based apps.
> Jody Garnett
> On Friday, 30 December 2011 at 6:48 PM, Brian Hamlin wrote:
> jsanz tells me that GeoNetwork is also running well under OpenJDK for
> him
> let this thread be an entrypoint for Java-app contacts to express their
> enthusiasm, dismay, pain, resignation or otherwise on the adaptation
> of an OpenJDK-only LiveDVD release
> best regards from Berkeley, California
> Brian Hamlin
> GeoCal
> OSGeo California Chapter
> 415-717-4462 cell
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
Jorge Sanz
http://es.osgeo.org
More information about the Live-demo
