[Live-demo] Postgres Apps - MapFish Sahana RasdamanPGRoutingGPSDrive
maplabs at light42.com maplabs at light42.com
Mon Jan 23 12:05:58 EST 2012
Daniel-san:
actually, the 9.1 package is already in place..
I simply changed the number 8.4 to 9.1 in the install script, and
everything just worked
as far as pgRouting packages, yes, I see your point
someone would have to update pgRouting in that case
postgres 8.4 is four to five years old at this point
best regards
  -Brian
On Mon, 23 Jan 2012 09:58:26  0900, Daniel Kastl
<daniel at georepublic.de> wrote:
pgRouting is probably not going to work with 9.1, because the pgRouting
packages on Launchpad are built for 8.4 for (X)ubuntu 11.04.It would be
quite some extra work to just build packages for 9.1 and 11.04, which I
would like to avoid, because these packages already exist for 11.10 (on
my PC) and there were some patches necessary. And I don't want to
revert to a script again to download, compile and install ;-)
So I'm -1 to install some "non-official" PostgreSQL version on this
LiveDVD release. It will be just a matter of six months to have 9.1
anyway if we will upgrade to 12.04. IMO, if 9.1 is so important we
should have used 11.10 for this release.
Daniel
On Mon, Jan 23, 2012 at 5:16 AM,  <maplabs at light42.com> wrote:
Compatability for Postgres 9.1 is in the 90%   range
The problem people run into is that since Postgres is a fundemental
piece of any stack,
it is some work to rebuild the stack to test with a new version...
I would be surprised if there are any compatability problems at all for
most all apps
other than people hard-coding version numbers and the like
  -Brian
On Mon, 23 Jan 2012 06:46:57  1100, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
Brian,
Based upon Peter's request, my feeling is that we should revert back to
Postgres 8.4. Our emphasis on OSGeo-Live is "stability over cutting
edge". This is because we are targeting new users who will be very
quickly turned off if they find a bug, and will generally not be
looking to check out the latest and greatest. (They can always go to a
project page later if they want to find latest features). Anyone wish
to weigh in on this topic before we make a call on which posgres to use?
On 22/01/12 20:55, Peter Baumann wrote:
> Hi Brian,
> sorry, we have not tested rasdaman with PG 9.x yet. Given the short >
> time remaining and current project pressure we won't be able to do so
> > for this DVD roll-out. As in the past even minor release changes in
> PG > have led to incompatibilities this deserves special attention.
> We'd > kindly ask you therefore to keep 8.4 available. >
> thanks for your understanding,
> Peter
> On 01/22/2012 06:15 AM, maplabs at light42.com wrote:
>> Hi All-
>>    I just changed the Postgres version to   9.1
>> install scripts for the applications listed above explicitly call out a
>> postgres version  (8.4)
>> Please check your app install scripts as we transition to the improved
>> 9.1 postgres base
>> thanks!
>> Brian Hamlin
>> GeoCal
>> OSGeo California Chapter
>> 415-717-4462 cell
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
-- Cameron Shorter
Geospatial Solutions Manager
Tel:  61 (0)2 8570 5050
Mob:  61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
More information about the Live-demo mailing list
