[Live-demo] [OSGeo] #932: Geonetwork map area not working
OSGeo
trac_osgeo at osgeo.org
Wed Jul 18 04:38:51 PDT 2012
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: LiveDVD | Keywords: 6.0
Comment(by fxp):
The exception in !GeoServer log is:
- GEOSERVER_DATA_DIR: /usr/lib/geonetwork/jetty/../data/geoserver_data
2012-07-18 19:15:43,119 WARN [referencing.factory] - Axis elements found
in a wkt definition, the force longitude first axis order hint might not
be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST],
AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2012-07-18 19:15:45,062 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'gwcXmlConfig' defined in URL
[jar:file:/tmp/Jetty_0_0_0_0_8880_geoserver.war__geoserver__.1dol4h/webapp
/WEB-INF/lib/gwc-2.0.2.jar!/applicationContext.xml]: Instantiation of bean
failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.geowebcache.config.XMLConfiguration]:
Constructor threw exception; nested exception is
com.thoughtworks.xstream.converters.ConversionException: Cannot construct
org.geowebcache.layer.wms.WMSLayer as it does not have a no-args
constructor : Cannot construct org.geowebcache.layer.wms.WMSLayer as it
does not have a no-args constructor
---- Debugging information ----
message : Cannot construct org.geowebcache.layer.wms.WMSLayer
as it does not have a no-args constructor
cause-exception :
com.thoughtworks.xstream.converters.reflection.ObjectAccessException
cause-message : Cannot construct org.geowebcache.layer.wms.WMSLayer
class : org.geowebcache.config.GeoWebCacheConfiguration
required-type : org.geowebcache.layer.wms.WMSLayer
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
"jetty/logs/geoserver.log" 108L, 11187C
I'm not sure why this is happening, but it's related to GWC. What I
suggest is to turn off GWC.
What I did and tested on the beta1 on virtual box:
# Goto GN folder
cd /usr/lib/geonetwork/web
# Unzip GeoServer war
mkdir geoserver
mv geoserver.war geoserver/.
cd geoserver/
unzip geoserver.war
# Remove GWC
cd WEB-INF/lib
rm geowebcache-1.2.2.jar
rm gwc-2.0.2.jar
rm web-gwc-2.0.2.jar
cd ../../
# Rebuild the war
rm geoserver.war
zip -r geoserver.war *
mv geoserver.war ../.
# Clean
cd ..
rm -fr geoserver
# And GeoNetwork start with a working background map.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/932#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
