[Live-demo] uDig in OSGeoLive 6.0 without JAI (and other java apps)
Cameron Shorter
cameron.shorter at gmail.com
Sun Jul 22 16:08:42 PDT 2012
Angelos,
You have noted that Geomajas doesn't work with JAI moved into the
classpath. Do you know of other java applications also effected?
In IRC a few hours ago, Jody mentioned the version of geotools being
used as a factor.
I'm expanding this conversation out to a few other java project contacts
who may have ideas to add.
On 23/07/2012 8:50 AM, Angelos Tzotsos wrote:
> Hi all,
> We are having trouble making uDig work on the live disk without custom
> jre.
> After removing custom jre and copying JAI jars and binaries in openjdk
> folders uDig works great but this breaks some other java applications.
> We have 2 options:
> 1. find a way for uDig to load JAI through a custom directory (even
> though an export LD_LIBRARY_PATH for a custom path did not work in
> Ubuntu)
> 2. use a pure java implementation of uDig without JAI
> The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
> Thoughts?
> Regards,
> Angelos
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
