[Live-demo] [OSGeo] #956: deegree startup shows errors
OSGeo
trac_osgeo at osgeo.org
Sun Jul 22 20:52:05 PDT 2012
Reporter: darkblueb | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive6.0RC1
Component: LiveDVD | Keywords: deegree
user at osgeolive:/usr/local/geomoose$ JAVA_HOME=/usr/lib/jvm/default-java sh
/usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/bin/catalina.sh debug
Using CATALINA_BASE: /usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35
Using CATALINA_HOME: /usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35
Using CATALINA_TMPDIR: /usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/temp
Using JAVA_HOME: /usr/lib/jvm/default-java
Using CLASSPATH: /usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/bin/bootstrap.jar
Initializing jdb ...
> classes
Command 'classes' is not valid until the VM is started with the 'run'
command
> run
run org.apache.catalina.startup.Bootstrap start
Set uncaught java.lang.Throwable
Set deferred uncaught java.lang.Throwable
VM Started: java.util.logging.ErrorManager: 4
java.io.FileNotFoundException: /usr/local/lib/deegree-webservices-3.2
-pre3_apache-tomcat-6.0.35/logs/catalina.2012-07-22.log (Permission
denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:212)
at org.apache.juli.FileHandler.openWriter(FileHandler.java:374)
at org.apache.juli.FileHandler.<init>(FileHandler.java:99)
at org.apache.juli.FileHandler.<init>(FileHandler.java:90)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at
org.apache.juli.ClassLoaderLogManager.readConfiguration(ClassLoaderLogManager.java:515)
at
org.apache.juli.ClassLoaderLogManager.readConfiguration(ClassLoaderLogManager.java:460)
at
org.apache.juli.ClassLoaderLogManager.readConfiguration(ClassLoaderLogManager.java:286)
at java.util.logging.LogManager$2.run(LogManager.java:285)
at java.security.AccessController.doPrivileged(Native Method)
at
java.util.logging.LogManager.readPrimordialConfiguration(LogManager.java:283)
at java.util.logging.LogManager.getLogManager(LogManager.java:266)
at java.util.logging.Logger.<init>(Logger.java:252)
at
java.util.logging.LogManager$RootLogger.<init>(LogManager.java:1136)
at
java.util.logging.LogManager$RootLogger.<init>(LogManager.java:1133)
at java.util.logging.LogManager$1.run(LogManager.java:198)
at java.util.logging.LogManager.<clinit>(LogManager.java:175)
at java.util.logging.Logger.getLogger(Logger.java:327)
at
org.apache.juli.logging.DirectJDKLog.<init>(DirectJDKLog.java:71)
at
org.apache.juli.logging.DirectJDKLog.getInstance(DirectJDKLog.java:178)
at
org.apache.juli.logging.LogFactory.getInstance(LogFactory.java:171)
at
org.apache.juli.logging.LogFactory.getInstance(LogFactory.java:243)
at org.apache.juli.logging.LogFactory.getLog(LogFactory.java:298)
at
org.apache.catalina.startup.Bootstrap.<clinit>(Bootstrap.java:55)
-pre3_apache-tomcat-6.0.35/logs/localhost.2012-07-22.log (Permission
denied)
Method)
at
at
at
at
at
at
at
at
at
at
at
at
at
-pre3_apache-tomcat-6.0.35/logs/manager.2012-07-22.log (Permission denied)
Method)
at
at
at
at
at
at
at
at
at
at
at
at
at
-pre3_apache-tomcat-6.0.35/logs/host-manager.2012-07-22.log (Permission
denied)
Method)
at
at
at
at
at
at
at
at
at
at
at
at
at
Jul 22, 2012 10:05:53 PM org.apache.catalina.core.AprLifecycleListener
init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path: /usr/java/packages/lib/i386:/usr/lib/i386-linux-
gnu/jni:/lib/i386-linux-gnu:/usr/lib/i386-linux-
gnu:/usr/lib/jni:/lib:/usr/lib
Jul 22, 2012 10:05:53 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8033
Jul 22, 2012 10:05:53 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1757 ms
Jul 22, 2012 10:05:54 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jul 22, 2012 10:05:54 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
Jul 22, 2012 10:05:54 PM org.apache.catalina.startup.HostConfig
deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
Jul 22, 2012 10:05:54 PM org.apache.jasper.EmbeddedServletOptions <init>
SEVERE: The scratchDir you specified: /usr/local/lib/deegree-
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/host-
manager is unusable.
deployDescriptor
INFO: Deploying configuration descriptor manager.xml
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/manager
is unusable.
deployDirectory
INFO: Deploying web application directory deegree-webservices
Jul 22, 2012 10:05:55 PM com.sun.faces.config.ConfigureListener
contextInitialized
INFO: Initializing Mojarra 2.0.6 (FCS FCS) for context '/deegree-
webservices'
Jul 22, 2012 10:05:58 PM
com.sun.faces.config.ConfigureListener$WebConfigResourceMonitor$Monitor
<init>
INFO: Monitoring jndi:/localhost/deegree-webservices/WEB-INF/faces-
config.xml for modifications
Jul 22, 2012 10:05:58 PM com.sun.jersey.api.core.PackagesResourceConfig
init
INFO: Scanning for root resource and provider classes in the packages:
org.deegree.services
Jul 22, 2012 10:05:58 PM com.sun.jersey.api.core.ScanningResourceConfig
logClasses
INFO: Root resource classes found:
class org.deegree.services.wps.wsdl.WSDLResource
logClasses
INFO: Provider classes found:
class org.deegree.services.wps.wsdl.WSDLWriter
Jul 22, 2012 10:05:59 PM
com.sun.jersey.server.impl.application.WebApplicationImpl _initiate
INFO: Initiating Jersey application, version 'Jersey: 1.5 01/14/2011 12:36
PM'
[22:06:00] INFO: [OGCFrontController]
[22:06:00] INFO: [OGCFrontController] _
[22:06:00] INFO: [OGCFrontController] _| | ___ ___ ___ _ _ ___ ___
3
[22:06:00] INFO: [OGCFrontController] / . |/ ._>/ ._>/ . || '_>/ ._>/ ._>
[22:06:00] INFO: [OGCFrontController] \___|\___.\___.\_. ||_| \___.\___.
[22:06:00] INFO: [OGCFrontController] <___'
[22:06:00] INFO: [OGCFrontController] deegree modules
[22:06:01] ERROR: [Reflections] could not create Vfs.Dir from url.
ignoring the exception and continuing
org.reflections.ReflectionsException: could not create Vfs.Dir from url,
no matching UrlType was found [file:/usr/lib/i386-linux-gnu/jni/libatk-
wrapper.so.0.0.18]
either use fromURL(final URL url, final List<UrlType> urlTypes) or use the
static setDefaultURLTypes(final List<UrlType> urlTypes) or
addDefaultURLTypes(UrlType urlType) with your specialized UrlType.
at org.reflections.vfs.Vfs.fromURL(Vfs.java:104)
at org.reflections.vfs.Vfs.fromURL(Vfs.java:89)
at org.reflections.Reflections.scan(Reflections.java:136)
at org.reflections.Reflections.<init>(Reflections.java:91)
at
org.deegree.commons.modules.ModuleInfo.extractModuleInfo(ModuleInfo.java:221)
at
org.deegree.commons.modules.ModuleInfo.extractModulesInfo(ModuleInfo.java:192)
at
org.deegree.commons.modules.ModuleInfo.<clinit>(ModuleInfo.java:82)
at
org.deegree.services.controller.OGCFrontController.init(OGCFrontController.java:1007)
at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1206)
at
org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1026)
at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4421)
at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4734)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
at
org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1079)
at
org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1002)
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:506)
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at
org.apache.catalina.core.StandardService.start(StandardService.java:525)
at
org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
[22:06:02] INFO: [OGCFrontController] - deegree-core-annotations-3.2-pre3
(svn revision 32612 build at 20111219-1824 by hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-core-base-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-core-commons-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-core-coverage-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-core-cs-3.2-pre3 (svn
filterfunctions-3.2-pre3 (svn revision 32612 build at 20111219-1824 by
hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-core-geometry-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-core-layer-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-core-metadata-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-core-rendering-
2d-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-core-style-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-core-theme-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-core-tile-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-featurestore-
commons-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
memory-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
shape-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
simplesql-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-featurestore-sql-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-javacheck-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-jsf-console-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-jsf-core-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-layers-coverage-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-layers-remotewms-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-layers-tile-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-mdstore-commons-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-mdstore-iso-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-ogcschemas-20110513 (svn
revision 20110826-1648 build at 20110826-1648 by markus)
[22:06:02] INFO: [OGCFrontController] - deegree-protocol-wms-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-remoteows-
[22:06:02] INFO: [OGCFrontController] - deegree-remoteows-wms-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-commons-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-config-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-csw-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-wfs-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-wms-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-services-wps-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-sqldialect-
postgis-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-themes-remotewms-3.2-pre3
[22:06:02] INFO: [OGCFrontController] - deegree-tilestore-
geotiff-3.2-pre3 (svn revision 32612 build at 20111219-1824 by hudson)
[22:06:02] INFO: [OGCFrontController] - deegree-tomcat-3.2-pre3 (svn
[22:06:02] INFO: [OGCFrontController] - deegree-webservices (svn revision
[22:06:02] INFO: [OGCFrontController] System info
[22:06:02] INFO: [OGCFrontController] - java version 1.7.0_03
(Oracle Corporation)
[22:06:02] INFO: [OGCFrontController] - operating system Linux
(3.2.0-26-generic, i386)
[22:06:02] INFO: [OGCFrontController] - webapp path /deegree-
webservices
[22:06:02] INFO: [OGCFrontController] - default encoding UTF-8
[22:06:02] INFO: [OGCFrontController] - system encoding UTF-8
[22:06:02] INFO: [OGCFrontController] - temp directory /usr/local/lib
/deegree-webservices-3.2-pre3_apache-tomcat-6.0.35/temp
[22:06:02] INFO: [OGCFrontController] Initializing workspace
[22:06:02] INFO: [OGCFrontController] - deegree workspace root
/usr/local/bin/deegree-webservices-3.2-pre3_apache-tomcat-6.0.35/webapps
/deegree-webservices/resources/deegree-workspaces
[22:06:02] WARN: [OGCFrontController] *** The workspace root is not
writable. ***
[22:06:02] WARN: [OGCFrontController] *** This will lead to problems when
you'll try to download workspaces. ***
[22:06:02] INFO: [OGCFrontController] Using default workspace (WEB-
INF/workspace_name does not exist)
[22:06:02] INFO: [OGCFrontController] Active workspace in webapp.
[22:06:02] INFO: [OGCFrontController] Using workspace 'default(external)'
at '/usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/webapps/deegree-webservices/WEB-INF/workspace'
[22:06:02] INFO: [DeegreeWorkspace] Not loading additional modules.
[22:06:02] INFO: [CRSManager]
[22:06:02] INFO: [CRSManager] No 'crs' directory -- use default
configuration.
[22:06:02] INFO: [CRSManager] Setting up crs store 'default' from file
'file:/usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/webapps/deegree-webservices/WEB-INF/lib/deegree-core-
cs-3.2-pre3.jar!/org/deegree/cs/persistence/default.xml'...
[22:06:03] INFO: [CRSManager] Registering global crs store with id
'default', type: 'org.deegree.cs.persistence.deegree.d3.DeegreeCRSStore'
[22:06:03] INFO: [ProxyUtils] No 'proxy.xml' file -- skipping set up of
proxy configuration.
[22:06:03] INFO: [JDBCParamsManager] Found and loaded org.h2.Driver
org.postgresql.Driver
[22:06:03] INFO: [AbstractResourceManager] No 'jdbc/' directory --
skipping initialization of jdbc params.
[22:06:03] INFO: [ConnectionManager] No 'jdbc' connections defined --
skipping initialization of JDBC connection pools.
[22:06:03] INFO: [CRSManager] Could not set up CRS stores: CRS workspace
directory /usr/local/lib/deegree-webservices-3.2-pre3_apache-
tomcat-6.0.35/webapps/deegree-webservices/WEB-INF/workspace/crs is null or
does not exist.
[22:06:03] INFO: [FunctionManager] Loading functions...
[22:06:04] INFO: [AbstractResourceManager] No 'datasources/metadata/'
directory -- skipping initialization of metadata stores.
[22:06:04] INFO: [SecurityConfiguration] No security.xml found.
[22:06:04] INFO: [AbstractResourceManager] No 'services/' directory --
skipping initialization of service metadata.
[22:06:04] INFO: [AbstractResourceManager] No 'styles/' directory --
skipping initialization of styles.
[22:06:04] INFO: [AbstractResourceManager] No 'datasources/coverage/'
directory -- skipping initialization of coverage stores.
[22:06:04] INFO: [AbstractResourceManager] No 'datasources/remoteows'
directory -- skipping initialization of remote OWS stores.
[22:06:04] INFO: [AbstractResourceManager] No 'datasources/tile/'
directory -- skipping initialization of tile stores.
[22:06:04] INFO: [AbstractResourceManager] No 'layers/' directory --
skipping initialization of layers.
[22:06:04] INFO: [AbstractResourceManager] No 'themes/' directory --
skipping initialization of themes.
[22:06:04] INFO: [BBoxPropertiesCache] File '/usr/local/lib/deegree-
webservices-3.2-pre3_apache-tomcat-6.0.35/webapps/deegree-webservices/WEB-
INF/workspace/datasources/feature/bbox_cache.properties' does not exist.
Will be created as needed.
[22:06:04] INFO: [TempFileManager] Using '/usr/local/lib/deegree-
webservices-3.2-pre3_apache-tomcat-6.0.35/temp/deegree-64751adf-b100-443e-
bfe2-fff82f761fe6' for storing temporary files.
[22:06:04] INFO: [FeatureStoreManager] Using '/usr/local/lib/deegree-
bfe2-fff82f761fe6/lockdb' for h2 lock database.
[22:06:04] INFO: [AbstractResourceManager] No 'datasources/feature/'
directory -- skipping initialization of feature stores.
[22:06:04] INFO: [AbstractResourceManager] No 'processes' directory --
skipping initialization of processes.
[22:06:04] INFO: [CSWProvider] Init CSW Provider
[22:06:04] INFO: [WebServicesConfiguration] No 'services/' directory --
skipping initialization of web services.
J[22:06:04] INFO: [OGCFrontContrul 22, 2012 9:06:04 PM
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/deegree-
webservices is unusable.
oller]
[22:06:04] WARN: [JAXBUtils] Not fixing JAXB classloader leaks. Code
needs updating.
[22:06:04] INFO: [ConfigServlet] deegree 3 configuration servlet started.
Jul 22, 2012 9:06:04 PM org.apache.catalina.startup.HostConfig
deployDirectory
INFO: Deploying web application directory docs
Jul 22, 2012 9:06:04 PM org.apache.jasper.EmbeddedServletOptions <init>
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/docs is
unusable.
deployDirectory
INFO: Deploying web application directory examples
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/examples
is unusable.
deployDirectory
INFO: Deploying web application directory ROOT
webservices-3.2-pre3_apache-tomcat-6.0.35/work/Catalina/localhost/_ is
unusable.
Jul 22, 2012 9:06:04 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8033
Jul 22, 2012 9:06:05 PM org.apache.jk.common.ChannelSocket init
INFO: Port busy 8009 java.net.BindException: Address already in use
SEVERE: Can't find free port 8009 8009
Jul 22, 2012 9:06:05 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/60 config=null
Jul 22, 2012 9:06:05 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 11170 ms
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/956>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
