[Live-demo] uDig in OSGeoLive 6.0 without JAI (and other java apps)
    Jody Garnett
    jody.garnett at gmail.com
    Sun Jul 22 22:41:56 PDT 2012
We actually have three things to track here:
- JAI
- ImageIO
- ImageIO-Ext (this will make use of GDAL binaries if they are available on the LD_LIBRARY_PATH, or installed into jre/bin)
I was concerned about GeoMajas using an older copy of GeoTools; and ending up requiring a different version of ImageIO-Ext (and thus GDAL) then the other projects.
>From a recent announcement (http://www.geomajas.org/node/629) it looks like GeoTools 2.7.5 is expected. This release of GeoTools (http://jira.codehaus.org/secure/ReleaseNote.jspa?projectId=10270&version=18236) works with ImageIO 1.1.x stream and should be compatible with the same ImageIO-Ext as GeoServer and uDig (which are starting to make use of GeoTools 8).
Jody Garnett
On Monday, 23 July 2012 at 9:39 AM, Angelos Tzotsos wrote:
> Cameron,
> So far only Geomajas seems affected but we need more testing to be sure
> about the other Java projects.
> Cheers,
> Angelos
> On 07/23/2012 02:08 AM, Cameron Shorter wrote:
> > Angelos,
> > You have noted that Geomajas doesn't work with JAI moved into the
> > classpath. Do you know of other java applications also effected?
> > In IRC a few hours ago, Jody mentioned the version of geotools being
> > used as a factor.
> > I'm expanding this conversation out to a few other java project
> > contacts who may have ideas to add.
> > On 23/07/2012 8:50 AM, Angelos Tzotsos wrote:
> > > Hi all,
> > > We are having trouble making uDig work on the live disk without
> > > custom jre.
> > > After removing custom jre and copying JAI jars and binaries in
> > > openjdk folders uDig works great but this breaks some other java
> > > applications.
> > > We have 2 options:
> > > 1. find a way for uDig to load JAI through a custom directory (even
> > > though an export LD_LIBRARY_PATH for a custom path did not work in
> > > Ubuntu)
> > > 2. use a pure java implementation of uDig without JAI
> > > The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
> > > Thoughts?
> > > Regards,
> > > Angelos
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> Live-demo mailing list
> Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120723/4df7c704/attachment.html>
More information about the Live-demo
