[Live-demo] [OSGeo] #955: language support missing packages
Alex Mandel tech_dev at wildintellect.com
Mon Jul 23 09:56:27 PDT 2012
On 07/23/2012 03:00 AM, Micha Silver wrote:
> On 7/23/2012 11:51 AM, edgar.soldin at web.de wrote:
>>>   Reporter:  hamish   |       Owner:  live-demo@…
>>>       Type:  task     |      Status:  new
>>>   Priority:  normal   |   Milestone:
>>> Component:  LiveDVD  |    Keywords:  6.0, i18n
>>> Comment(by micha):
>>>   Actually I think the language switcher is not working as expected. You can
>>>   add a second language, and the keyboard layout switches when clicking on
>>>   the icon. But the chosen key combination (i.e. Alt-Shift) to switch
>>>   between languages does not seem to work. (I see this on two VM's.
>> could as well be a vm key mapping issue. at least vmware has an issue with ALTGr which is mapped to STRG+ALT for some reason and this way clashes with the key combination to leave the vm.
> I have other VM's (EL 6.2) running on the same machines, and no problems
> switching between keyboard mappings there.
>> just an idea... ede
I just booted a recent Beta, and it looks like the keyboard binding
simply isn't set. Possibly because no additional keyboard configs have
been specified.
Once I add a 2nd keyboard layout and select a hotkey to use in the
properties it seems to work fine.
Thanks,
Alex
More information about the Live-demo mailing list
