[Live-demo] [OSGeo] #959: geomajas installs old version on OSGeo-Live
OSGeo trac_osgeo at osgeo.org
Mon Jul 23 15:45:26 PDT 2012
 Reporter:  camerons  |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  OSGeoLive6.0Final
Component:  LiveDVD   |    Keywords:  6.0, geomajas
 As of OSGeoLive 6.0beta4, the geomajas install script [1] installs version
 1.8.0 rather than the latest stable version of 1.11.
 [1]
 https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_geomajas.sh
 We believe that this is also linked to geomajas not working in 6.0beta4
 when the Java Advanced Imaging (JAI) library was copied into the main java
 library.
 The following email thread [2] should provide insights:
 On 07/23/2012 08:41 AM, Jody Garnett wrote:
 > We actually have three things to track here:
 > - JAI
 > - ImageIO
 > - ImageIO-Ext (this will make use of GDAL binaries if they are available
 on the LD_LIBRARY_PATH, or installed into jre/bin)
 > I was concerned about GeoMajas using an older copy of GeoTools; and
 ending up requiring a different version of ImageIO-Ext (and thus GDAL)
 then the other projects.
 > >From a recent announcement (http://www.geomajas.org/node/629) it looks
 like GeoTools 2.7.5 is expected. This release of GeoTools
 (http://jira.codehaus.org/secure/ReleaseNote.jspa?projectId=10270&version=18236)
 works with ImageIO 1.1.x stream and should be compatible with the same
 ImageIO-Ext as GeoServer and uDig (which are starting to make use of
 GeoTools 8).
 Hi Jody,
 Geomajas on the DVD is still in version 1.8.0.
 The link you provided was referring to Geomajas 1.11.0
 [2] http://lists.osgeo.org/pipermail/live-demo/2012-July/005618.html
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/959>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
