[Live-demo] [OSGeo] #960: Sahana demo not working
OSGeo
trac_osgeo at osgeo.org
Tue Jul 24 04:45:09 PDT 2012
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive6.0RC1
Component: LiveDVD | Keywords: 6.0, sahana
Changes (by hamish):
* cc: flavour (added)
* keywords: 6.0 => 6.0, sahana
Comment:
see http://lists.osgeo.org/pipermail/live-demo/2012-July/005628.html
Cloning into 'web2py'...
./install_sahana.sh: 145: cd: can't cd to eden
fatal: Not a git repository (or any of the parent directories): .git
Cloning into 'eden'...
Note: checking out 'c62909947dc12530c65563dace8a87def93f962f'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b new_branch_name
HEAD is now at c629099... Restrict access to req_match & hide commit tab
if req_use_commit=False
HEAD is now at c629099 Restrict access to req_match & hide commit tab if
chown: cannot access `/usr/local/lib/web2py/applications/admin/cache': No
such file or directory
WARNING: S3Msg unresolved dependency: tweepy required for non-Tropo
Twitter support
WARNING: Survey unresolved dependency: PyRTF required if you want to
export assessment templates as a Word document
DEBUG: connect attempt 0, connection error:
File "/usr/local/lib/web2py/gluon/dal.py", line 6481, in __init__
self._adapter = ADAPTERS[self._dbname](*args)
File "/usr/local/lib/web2py/gluon/dal.py", line 2265, in __init__
self.pool_connection(connect)
File "/usr/local/lib/web2py/gluon/dal.py", line 526, in pool_connection
self.connection = f()
File "/usr/local/lib/web2py/gluon/dal.py", line 2264, in connect
return self.driver.connect(msg,**driver_args)
File "/usr/lib/python2.7/dist-packages/psycopg2/__init__.py", line 179,
in connect
connection_factory=connection_factory, async=async)
OperationalError: FATAL: password authentication failed for user "sahana"
[and a bunch more like that]
File "web2py.py", line 25, in <module>
gluon.widget.start(cron=True)
File "/usr/local/lib/web2py/gluon/widget.py", line 926, in start
import_models=options.import_models, startfile=options.run)
File "/usr/local/lib/web2py/gluon/shell.py", line 198, in run
_env = env(a, c=c, f=f, import_models=import_models)
File "/usr/local/lib/web2py/gluon/shell.py", line 131, in env
run_models_in(environment)
File "/usr/local/lib/web2py/gluon/compileapp.py", line 510, in
run_models_in
restricted(code, environment, layer=model)
File "/usr/local/lib/web2py/gluon/restricted.py", line 205, in
restricted
exec ccode in environment
File "applications/eden/models/00_db.py", line 76, in <module>
raise(HTTP(503, "Cannot connect to %s Database: %s" % (db_type,
db_location)))
gluon.http.HTTP: 503 SERVICE UNAVAILABLE
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/960#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
