[Live-demo] [udig-devel] uDig in OSGeoLive 6.0 without JAI
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jul 25 17:29:50 PDT 2012
Hi Frank, all,
Can you please take a look here:
https://trac.osgeo.org/osgeo/changeset/8349
Comments?
Cheers,
Angelos
On 07/24/2012 11:04 AM, Frank Gasdorf wrote:
> Andrea,
> Absolutely agree, this would not work because of missing jars in
> classpath. I tried to find a way to give the eclipse launcher an
> external classpath but haven't found anything yet. Because of multiple
> classloaders there is no way to work with classpath settings. The RFC
> http://udig.refractions.net/confluence/display/UDIG/native+support+bundles+for+java+advanced+imaging
> would solve this because jai libs and natives are bundled and would
> not required jai in the JRE.
> HACK : What about making symbolic links from udig_home/jre to the
> open-jdk-7 installation files/folders and let the jai/imageio jars
> locally in the lib/ext folder. To make sure udig uses the right JRE
> set the launcher option "-vm" to the udig_home/jre path.
> All other options would require a new release and of course a finished
> RFC ;) --> next release cycle of OSGeo Live is much more realistic
> BTW: Any news from Andrew about JAI/ImageIO Licensing and
> redistributing as a bundle (see RFC again)
> Cheers,
> Frank
> 2012/7/24 andrea antonello <andrea.antonello at gmail.com>:
>>> I moved the jai binaries and jars into a custom folder under udig.
>>> Then I added this line on start of udig.sh, right under the gdal line:
>>> export LD_LIBRARY_PATH=LD_LIBRARY_PATH:/usr/lib/udig/jai/ext/
>> That would work for the native libs, but then you do not have the jars
>> in the classpath.
>> Also I am not sure if that then picks imageio-ext.
>> I am afraid I am not following this discussion tightly, but the above
>> can't work in my opinion.
>> Frank, you worked on this, do you have opinions about this?
>> Andrea
>>> 2. use a pure java implementation of uDig without JAI
>>> I am not keen to make a special copy of uDig just for the live dvd.
>>> The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
>>> Thoughts?
>>> You only mentioned JAI here; are you also looking at ImageIO and
>>> ImageIO-Ext? Other projects such as Geomajas are more likely to conflict on
>>> the copy of ImageIO-Ext and GDAL used.
>>> I did not touch either ImageIO or GDAL, since udig seemed to open every file
>>> I tested just with JAI moved around.
>>> Jody
>>> User-friendly Desktop Internet GIS (uDig)
>>> http://lists.refractions.net/mailman/listinfo/udig-devel
>>> Angelos Tzotsos
>>> Remote Sensing Laboratory
>>> National Technical University of Athens
>>> http://users.ntua.gr/tzotsos
Angelos Tzotsos
More information about the Live-demo
