[Live-demo] [OSGeo] #972: rasdaman: install script full of ugly
OSGeo
trac_osgeo at osgeo.org
Tue Jul 31 04:13:49 PDT 2012
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive6.0RC1
Component: LiveDVD | Keywords: 6.0, rasdaman
Comment(by hamish):
ok, try r8579 where --with-hdf4 has been removed. Note there is also a
libhdf4-alt-dev, maybe that helps. If you get really stuck with the hdf4
stuff you might try pinging Frankie on the DebianGIS list who did a lot of
the packaging. It is much preferable to stick with released versions (i.e.
known and tested codebases). The symlinks I commented out all weren't
being created anyway (see the errors in the build log), since the target
libs already existed there. I suspect some temporary LD_LIBRARY_PATH magic
may have helped instead of symlinks.
From here y'all will have to sort the rest of it out, I'm off to a remote
field station for a few days. :)
best,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/972#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
