[Live-demo] Alternative OSGeoLive build process
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sat Jun 2 02:32:14 PDT 2012
Hello Brian,
Yes the problem with the new method is that it does not have "user"
created. Instead it uses the default user when you select "Try Ubuntu"
instead of "Install Ubuntu" after booting the disk.
This means that we have to do the following:
1. Create a branch in svn for this new method
2. Fix packages to not use "user"
3. Not place any files in /home/user but select another folder instead
4. Refine the desktop in live mode (background image, etc)
Angelos
On 05/31/2012 10:29 PM, Brian Hamlin wrote:
> Kalxas -
> thank you for this log.. after reading a bit
> I do not understand what is going on with unknown user: user so many
> times
> or, chown user:user invalid user.. ?? it is affecting the database
> load scripts..
> more later
> -Brian
> Brian Hamlin
> GeoCal-ish
> OSGeo California Chapter
> 415-717-4462 cell
> On May 31, 2012, at 9:58 AM, Angelos Tzotsos wrote:
>> Hi all,
>> After talking with Alex, we thought to start testing a new build
>> system for osgeolive iso.
>> Alex has provided an initial script for this.
>> I managed to use this script and create a first version of osgeolive
>> iso.
>> I am uploading the log file from this test so we can all have a look
>> on what is breaking in this new process
>> http://aiolos.survey.ntua.gr/gisvm/6.0/osgeo-live-6.0alpha2-alternative.tar.gz
>> I am not going to publish this iso yet, I will wait to run a parallel
>> build this weekend for alpha3 and provide an iso.
>> Any thoughts?
>> Regards,
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos
More information about the Live-demo
