[Live-demo] Re: [OSGeo-Conf] Re: OSGeo Chinese translations
Cameron Shorter cameron.shorter at gmail.com
Mon May 14 18:11:30 EDT 2012
On 15/05/12 00:15, Tanner Lin wrote:
> Svn is synced on my side and working well. Translating.
Ok, good to hear.
> Got 3 questions:
> How often is adhoc.osgeo.osuosl.org/livedvd/docs updated from the svn ? Do I
> have to want a long time before any edit I make take effect ?
It should be updated every hour, although it might be every 24 hours.
Hamish should be able to confirm this. (Hamish, can we please ensure the
docs are turned around every hour now in order to support the translators).
> Wry do some records in the status spreadsheet shows "_complete" while the
> .rst file in the svn is not translated ?
Looking at subversion, it seems that someone has copied all English
versions of files into the the Chinese directory.
This is confusing the status spreadsheet, which only works on
timestamps, and can't tell the difference between Chinese and English
documents.
To fix this, I've removed the untranslated documents from the Chinese
translated directory.
(This is ok, because our build scripts automatically replace any
untranslated document with an English document)
So when you translate a document now, you will need to do a:
svn add filename
svn commit -m"Added new Chinese translated file" filename
> Are translators required to follow the English document strictly, or they
> can have some flexibility and put their own ideas into the translation ? For
> example, some Chinese GIS software vendors created a few data formats that
> is only popular in China. If I'm translating a document on format
> support/conversion, may I write a bit in my Chinese version to provide
> information on working with these formats ?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-OSGeo-Conf-Re-OSGeo-Chinese-translations-tp4970566p4974448.html
> Sent from the OSGeo FOSS4G LiveDVD mailing list archive at Nabble.com.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
