[Live-demo] Time for 6.0alpha2 build?
Cameron Shorter cameron.shorter at gmail.com
Sun May 20 19:13:55 EDT 2012
Angelos,
Yes, I think an alpha2 is a good idea.
I suggest sending an email with at least 24 hours notice before you
start, to give projects a chance to clean up any loose ends.
We can then follow up with emails to each project noting the status. I
can help with some of the communication if you like.
On 21/05/2012 7:17 AM, Hamish wrote:
> Angelos wrote:
>> I think we should move to building alpha2 to see the status
>> of packages.
>> Thoughts?
> sure, sounds good!
> I'm having a small problem trying to update GpsDrive to work
> on 12.04 with Mapnik 2 + PostGIS 2, maybe someone here has had
> similar troubles..? I think most of the problem is that I'm no
> cmake, libboost, and C++ expert so maybe it's a quick fix. I've
> added all the #ifdefs around the API changes, and it compiles
> ok, but is not linking to the libboost-system library so fails
> at the final stage of building the program.
> Linking CXX executable gpsdrive
> /usr/bin/ld: CMakeFiles/gpsdrive.dir/mapnik.o: undefined reference to
> symbol 'boost::system::system_category()'
> /usr/bin/ld: note: 'boost::system::system_category()' is defined in DSO
> /usr/lib/libboost_system.so.1.46.1 so try adding it to the linker command
> line
> /usr/lib/libboost_system.so.1.46.1: could not read symbols: Invalid
> operation
> collect2: ld returned 1 exit status
> make[3]: *** [src/gpsdrive] Error 1
> similar problem (but different symbol) if I try building the
> .deb on Debian/sid.
> any ideas? "target_link_libraries(mapnik.o boost-system)"? where?
> cheers,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
