[Live-demo] Which version of udig should be included on OSGeo-Live 6.0? - and build status.
Jody Garnett jody.garnett at gmail.com
Sun May 27 07:01:54 PDT 2012
I have no guidance until you sort out the issue of Java with all of the GeoTools based projects. There was recent interest in configuring a build box against OpenJDK 7 (no interest has been shown in OpenJDK 6). I would recommend catching up with Ben on this subject (as he seems to be the only community member with hardware to donate for the activity). We could also talk to SAC and see if they would be willing to run a "jenkins" build box?
I think the best you can hope for is to make these applications available with a note they are running in an "unsupported" configuration. If you have volunteers willing to test; you may be able to detect failures and bump them from the release.
For my own part:
- I am unable to investigate a failure in OpenJDK 6. An OpenJDK 7 is available for mac now; which may allow me to reproduce any problems found in that environment.
- uDig 1.3.2 is being delayed as I recover the build process from a transition to Maven which LISAsoft started (thanks!). While 1.3.2 is expected shortly; I am having some technical difficulties.
Jody Garnett
On Sunday, 27 May 2012 at 11:50 PM, cameron.shorter at gmail.com wrote:
> Dear Jody, Andrea,
> Did you see this email? What version of udig should be included on the
> next OSGeo-Live release?
> Version 1.2.2 of udig was included in the last 5.5 OSGeo-Live release.
> Also, in the latest 6.0alpha2 OSGeo-Live built by Angelos, udig
> seems to be working fine with sun-java but not with our target openjdk.
> Could you please investigate.
> The latest 6.0alpha2 image and compile logs are here:
> http://aiolos.survey.ntua.gr/gisvm/6.0/
> On 21/05/2012 9:31 PM, Cameron Shorter wrote:
> > We have started the release cycle for OSGeo-Live 6.0, which is due to be
> > released in September 2012, and I'd like someone from each OSGeo-Live
> > project to please touch base with me to let me know which version of the
> > application you expect to be included in the upcoming release.
> > This upcoming OSGeo-Live release will be based upon Xubuntu 12.04 LTS.
> > Feature Freeze for OSGeo-Live 6.0 will be 10 July 2012.
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120528/21a1f5d0/attachment.html>
More information about the Live-demo mailing list
