[Live-demo] JTS on OSGeo-Live
Cameron Shorter
cameron.shorter at gmail.com
Tue Nov 6 11:47:31 PST 2012
Stefan, Landon, (with help from Martin),
We have started our OSGeoLive build process, and need to know details
about projects which are to be included - especially any new projects.
By the end of this week, can you please put these details together, as per:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
On 25/10/12 07:15, Stefan Steiniger wrote:
> thanks Cameron.
> Sounds doable... now we need to coordinate.
> cheers from Santiago
> stefan
> Am 24.10.12 16:55, schrieb Cameron Shorter:
>> On 25/10/2012 12:20 AM, Stefan Steiniger wrote:
>>> Hi,
>>> thanks Jody!
>>> Having now this Ant build and a FAQ
>>> I am confused and have two questions to the liveDVD builders/Cameron:
>>> (i) what ToDo's are open? (proof reading?)
>> We need someone to officially apply to join the OSGeo-Live project, by
>> sending an email addressing our standard questions, as per:
>> We need someone to write an install_jst.sh script as per:
>> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Install_Script
>> The Application Overview needs to cover JTS's desktop application.
>> Ideally, someone will find or create a logo for JTS
>> Someone needs to write a Quickstart as per:
>> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Application_Quick_Start
>>> (ii) what is the timelime?
>> Schedule for the next OSGeo-Live release is currently being discussed.
>> If we follow the same schedule as last year, it will be something like:
>> feature freeze ~ early January 2013
>> all apps delivered to UAT ~ early February 2013
>> final ISO ~ early March 2013
>>> cheers,
>>> stefan
>>> Am 23.10.12 23:21, schrieb Brian Hamlin:
>>>> I "discovered" JTS Test Builder in 2007 (when I started in Geo).. it
>>>> would be a fine addition IMO
>>>> I still fire it up now and then.. Mac and Linux.. though not as
>>>> neatly as Jody
>>>> shown below.. and without ant..
>>>> cd $src_dir
>>>> java -classpath "jdom.jar:xerces.jar:JTS_Test.jar:jts-1.8.jar"
>>>> com.vividsolutions.jtstest.testbuilder.JTSTestBuilder
>>>> Brian Hamlin
>>>> OSGeo California Chapter
>>>> 415-717-4462 cell
>>>> On Oct 23, 2012, at 6:17 PM, Cameron Shorter wrote:
>>>>> I hope no one CCed minds if we take this thread back to the live
>>>>> email
>>>>> list, so we can capture the technical discussion.
>>>>> On 24/10/2012 12:13 PM, Jody Garnett wrote:
>>>>>> I have done the overview / fact sheet; waiting for a review on the
>>>>>> live-demo email list. For my purposes (explaining what GIS is as
>>>>>> part
>>>>>> of an "OSGeo-Live" talk) having the fact sheet is enough.
>>>>>> However the JTS desktop tool would be an *amazing* addition to
>>>>>> OSGeo-Live for use in an educational context, the ability to take a
>>>>>> class enter in a couple geometries and have them try out the
>>>>>> operations would be far better then explaining this in PostGIS and
>>>>>> pgAdmin.
>>>>>> install steps:
>>>>>> 1) Download
>>>>>> http://sourceforge.net/projects/jts-topo-suite/files/jts/1.12/jts-1.12.zip/download
>>>>>> 2) Unzip
>>>>>> 3) Copy in the following build.xml
>>>>>> <project name="JTS" basedir="." default="run">
>>>>>> <property name="lib" value="lib"/>
>>>>>> <property name="main-class"
>>>>>> value="com.vividsolutions.jtstest.testbuilder.JTSTestBuilder"/>
>>>>>> <path id="classpath">
>>>>>> <fileset dir="${lib}" includes="**/*.jar"/>
>>>>>> </path>
>>>>>> <target name="run">
>>>>>> <java fork="true" classname="${main-class}">
>>>>>> <classpath>
>>>>>> <path refid="classpath"/>
>>>>>> <path
>>>>>> location="${jar.dir}/${ant.project.name}.jar"/>
>>>>>> </classpath>
>>>>>> </java>
>>>>>> </target>
>>>>>> </project>
>>>>>> 4) Type the following on the command line:
>>>>>> ant
>>>>>> Jody Garnett
>>>>>> On Wednesday, 24 October 2012 at 10:57 AM, Stefan Steiniger wrote:
>>>>>>> Ah ok, I had the same question as Landon w.r.t. an installer.
>>>>>>> So the question remaining is Landons other question:
>>>>>>> What is the schedule?
>>>>>>> I could imagine to do the fact-sheet for JTS (though - its for JTS
>>>>>>> not
>>>>>>> the testbuilder - which I agree, is a nifty tool; at least for
>>>>>>> teaching)
>>>>>>> and maybe a short intro. But I think Landon did do the latter
>>>>>>> already?
>>>>>>> Installer... depends... maybe we can ask Ede from OJ for advise
>>>>>>> (but he
>>>>>>> also had a full plate ;)
>>>>>>> cheers,
>>>>>>> stefan
>>>>>>> Am 23.10.12 17:16, schrieb Martin Davis:
>>>>>>>> Right now you have to use a BAT/SH file to run them. I haven't
>>>>>>>> done
>>>>>>>> the work to make them JAR-launchable.
>>>>>>>> On Tue, Oct 23, 2012 at 12:58 PM, Landon Blake <lblake at ksninc.com>
>>>>>>>> wrote:
>>>>>>>>> Roger. Are those typically executed by double clicking on a JAR
>>>>>>>>> or by
>>>>>>>>> using a BAT file?
>>>>>>>>> Landon Blake, P.L.S.
>>>>>>>>> Project Surveyor
>>>>>>>>> Kjeldsen, Sinnock & Neudeck, Inc.
>>>>>>>>> 711 N. Pershing Avenue, Stockton CA 95203
>>>>>>>>> 209 946-0268 | fax: 209 946-0296
>>>>>>>>> lblake at ksninc.com | http://www.ksninc.com
>>>>>>>>> Warning:
>>>>>>>>> Information provided via electronic media is not guaranteed
>>>>>>>>> against defects including translation and transmission errors. If
>>>>>>>>> the reader is not the intended recipient, you are hereby notified
>>>>>>>>> that any dissemination, distribution or copying of this
>>>>>>>>> communication is strictly prohibited. If you have received this
>>>>>>>>> information in error, please notify the sender immediately.
>>>>>>>>> -----Original Message-----
>>>>>>>>> From: Martin Davis [mailto:mtnclimb at gmail.com]
>>>>>>>>> Sent: Tuesday, October 23, 2012 12:58 PM
>>>>>>>>> To: Landon Blake
>>>>>>>>> Cc: Cameron Shorter; Jody; Stefan Steiniger
>>>>>>>>> Subject: Re: [Live-demo] JTS on OSGeo-Live
>>>>>>>>> JTS comes with a couple of user-level tools - the TestBuilder
>>>>>>>>> and the
>>>>>>>>> TestRunner. The TestRunner is a bit esoteric, but the
>>>>>>>>> TestBuilder I
>>>>>>>>> think would make a fine tool to be installed on the Quickstart.
>>>>>>>>> M
>>>>>>>>> On Tue, Oct 23, 2012 at 12:33 PM, Landon Blake
>>>>>>>>> wrote:
>>>>>>>>>> JTS is an important library, so I will make time to assist.
>>>>>>>>>> I know a bit about the Quickstart. What do you mean by
>>>>>>>>>> "installer"?
>>>>>>>>>> JTS is really a library and not an application, so I'm not sure
>>>>>>>>>> what
>>>>>>>>>> we would need for an installer.
>>>>>>>>>> Let me know more about that and I will get started. What is our
>>>>>>>>>> timeline for this little project?
>>>>>>>>>> Landon
>>>>>>>>>> Project Surveyor
>>>>>>>>>> Warning:
>>>>>>>>>> against
>>>>>>>>> defects including translation and transmission errors. If the
>>>>>>>>> reader is
>>>>>>>>> not the intended recipient, you are hereby notified that any
>>>>>>>>> dissemination, distribution or copying of this communication is
>>>>>>>>> strictly
>>>>>>>>> prohibited. If you have received this information in error,
>>>>>>>>> please
>>>>>>>>>> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>>>>>>>>> Sent: Tuesday, October 23, 2012 12:24 PM
>>>>>>>>>> To: Martin Davis
>>>>>>>>>> Cc: Jody; Landon Blake; Stefan Steiniger
>>>>>>>>>> Landon, Stefan,
>>>>>>>>>> I'm wondering if either (or both) of you would be able to help
>>>>>>>>>> get JTS
>>>>>>>>>> onto OSGeo-Live.
>>>>>>>>>> Jody has started, by writing a Project Overview.
>>>>>>>>>> We still need an installer and Quickstart.
>>>>>>>>>> On Monday, 22 October 2012 at 11:59, Martin Davis wrote:
>>>>>>>>>> Guys,
>>>>>>>>>> I'm happy to have JTS included on OSGeo Live, but the sad fact
>>>>>>>>>> is I
>>>>>>>>>> just don't have any time right now to prepare the necessary
>>>>>>>>>> artifacts
>>>>>>>>> myself.
>>>>>>>>>> If someone else wants to take this on I'm happy to advise, but
>>>>>>>>>> otherwise JTS will have to continue to languish in obscurity...
>>>>>>>>>> Martin
>>>>>>>>>> On 23/10/12 10:48, Martin Davis wrote:
>>>>>>>>>>> On Mon, Oct 22, 2012 at 4:30 PM, Cameron Shorter
>>>>>>>>>>> <cameron.shorter at gmail.com> wrote:
>>>>>>>>>>>> Martin, if we find someone to write the docs and installer,
>>>>>>>>>>>> are
>>>>>>>>>>>> you
>>>>>>>>>>>> prepared to review it?
>>>>>>>>>>>> Can you suggest a likely candidate who might be willing to
>>>>>>>>>>>> help
>>>>>>>>>>>> out?
>>>>>>>>>>> Yes, certainly, happy to review it.
>>>>>>>>>>> Possibly Landon (Sunburned Surveyor)? He has been interested
>>>>>>>>>>> in JTS
>>>>>>>>>>> documentation in the past. Another possibility is Stefan
>>>>>>>>>>> Steineger.
>>>>>>>>>> Cameron Shorter
>>>>>>>>>> Geospatial Solutions Manager
>>>>>>>>>> Tel: +61 (0)2 8570 5050
>>>>>>>>>> Mob: +61 (0)419 142 254
>>>>>>>>>> Think Globally, Fix Locally
>>>>>>>>>> Geospatial Solutions enhanced with Open Standards and Open
>>>>>>>>>> Source
>>>>>>>>>> http://www.lisasoft.com
>>>>> -- Cameron Shorter Geospatial Solutions Manager Tel: +61 (0)2 8570
>>>>> 5050 Mob: +61 (0)419 142 254 Think Globally, Fix Locally Geospatial
>>>>> Solutions enhanced with Open Standards and Open Source
>>>>> _______________________________________________
>>>>> Live-demo mailing list
>>>>> Live-demo at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>> http://live.osgeo.org
Cameron Shorter
Geospatial Solutions enhanced with Open Standards and Open Source
More information about the Live-demo
