[Live-demo] What version of applications should we be installing on OSGeo-Live 6.5? - spatialite
Cameron Shorter cameron.shorter at gmail.com
Fri Nov 9 15:59:42 PST 2012
Micha,
That sounds like sound advice. We currently have spatialite 3.1.0~rc2
installed. Is there a stable 3.1.0 version we should use instead?
On 10/11/2012 3:11 AM, Micha Silver wrote:
> Regarding spatialite I'd suggest *not* to make any changes, even
> though there's a new version 4.0 that will be released as "stable" in
> time for the 6.5 LiveDVD. The problem is that gdal will not yet
> support the changes implemented in this new spatialite. So other
> packages, which use gdal to access spatialite DBs, won't be able to
> open a DB created with the newer 4.0 version.  Support in gdal for
> this version will probably not be until gdal 2.0 later in 2013.
> So even tho' the spatialite 4.0 offers some nice improvements (i.e.
> fast access to huge tables) we should hold off for now.
> Micha
> On 11/09/2012 09:54 AM, Cameron Shorter wrote:
>> Hi all,
>> We have started the OSGeo-Live build process for the next 6.5 release
>> and would like to know which version of each application we should
>> include on OSGeo-Live.
>> For the application(s) which you are responsible for, could you
>> please email me with the version that you expect should be installed.
>> If you will be changing the version of your application, could you
>> also update the installers script.
>> Our key milestones are:
>>     10 Dec 2012 All new applications installed, most old applications
>> updated
>>     24 Dec 2012 Feature Freeze (all apps updated)
>>     28 Jan 2012 User Acceptance Test (all apps installed and working)
>>     18 Feb 2012 Final ISO sent to printers
> Micha Silver
> GIS Consultant, Arava Development Co.
> http://www.surfaces.co.il
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20121110/7b0ce7bf/attachment.html>
More information about the Live-demo mailing list
