[Live-demo] which version of PostGIS on OSGeo-Live? What apps will be effected?
Brian Hamlin
maplabs at light42.com
Mon Nov 19 14:37:31 PST 2012
hmmm I would say it this way
OSGeo Live is a showcase of OSGeo software, no?
PostGIS 2.0 went final in April of 2012,
after two years+ of development and many thousands of hours of testing
put another way, it is now six months after 2.0 was released, and
will be nine by the time the Live ships
I am personally familiar with almost every upgrade issue, they are
all very contained
I suggest that PostGIS 2.0 become the default for the Live on this
release
all data sets are moved over, which I can do and others can help
and that 1.5 is offered as a side option/hack for projects that
*truly have unsolved problems*
no standard datasets in 1.5, only 2.0+
Brian Hamlin
OSGeo California Chapter
On Nov 19, 2012, at 1:58 PM, Cameron Shorter wrote:
> On 20/11/12 07:59, Brian Hamlin wrote:
>> On Nov 19, 2012, at 12:34 PM, Alex Mandel wrote:
>>> On 11/19/2012 11:57 AM, Cameron Shorter wrote:
>>>> On 20/11/12 00:39, Daniel Kastl wrote:
>>>>> Are there any plans to upgrade PostGIS to version 2.0? Because
>>>>> this
>>>>> could require some additional work for pgrouting then as it's
>>>>> not the
>>>>> default PostGIS version of 12.04 and 12.10
>>> Postgis 2.0 from ubuntugis-unstable (no change to the script
>>> required to
>>> get that).
>>> Some projects may not be able to use 2.0 yet, for those we should
>>> also
>>> retain 1.5. As Brian has pointed out it should be possible to
>>> have both.
>>> Possible method:
>>> Install Postgis 1.5 from ubuntu stock repos, then add ubuntugis
>>> to apt
>>> and install 2.0. 1.5 sql files might remain on the system which
>>> would
>>> then give us both. We'd want to make 2 different template dbs one
>>> thats
>>> 1.5 using the same name we have now and then a postgis 2.0 template
>>> under a different name so projects that want to use it can.
>> I can absolutely do this, my main concern is FUD from others
>> abuot non-standard installs
>> The PostGIS core team has been building and using 1.5 and 2.0 side
>> by side for more than two years
>> of course it works.. but there is a small matter of defaults, etc
> Ideally, I'd like to see only one version of PostGIS installed.
> Reasons:
> * Reduce confusion from new users questioning which version of
> postgis to use.
> * Reduce disk space used - would we need to load our default
> datasets into both versions of PostGIS?
> So I question whether we update all applications which make use of
> PostGIS.
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo
