[Live-demo] What version of applications should we be installing on OSGeo-Live 6.5? - for mapguide / fdo
Jackie Ng
jumpinjackie at gmail.com
Fri Nov 23 02:06:15 PST 2012
MapGuide Open Source 2.4.0 (and FDO 3.7) already has binary deb packages
for Ubuntu 12.04.
If the LiveDVD is only 32-bit applications, it may be quicker and easier to
use this binary release as the starting point instead of battling with gcc,
automake and friends.
However this still uses bundled Apache/PHP/Tomcat and the full CS-Map
dictionary set which as noted, may pose some problems when disk space is a
premium. Off the top of my head, the bits you can chop out to save disk
space include:
- CS-Map dictionary files that you won't ever use for the demo data set
(Sheboygan?): http://trac.osgeo.org/mapguide/ticket/1736
- Tomcat
- Unused modules from bundled Apache
- Unused extensions from bundled PHP
- All FDO providers except for SDF and SHP
- Jackie
On 20 November 2012 07:29, Cameron Shorter <cameron.shorter at gmail.com>wrote:
> On 20/11/12 07:17, Johan Van de Wauw wrote:
> I'll write a project overview for FDO (mostly reusing content from the
> fdo site - I'll have a look if I can find info on the licensing of that
> content).
> Ok, thanks, that would be great.
> For mapguide, I'm working on the svn version, this ensures that changes
> I might make can be more easily integrated in the project. Perhaps I can
> backport some changes, so it would be version 2.4 but more likely it will
> be a svn version after 2.4. But before promising too much: let's try to get
> a working version first!
> Ok, good luck with that.
> I'll make the assumption that you will be working against "2.4.1" for the
> moment. We can change later as required.
> Note that our big challenge will likely be fitting MapGuide onto
> OSGeo-Live, as MapGuide has historically taken up significantly more space
> than any other application.
> Johan
> On Sat, Nov 10, 2012 at 12:53 AM, Cameron Shorter <
> cameron.shorter at gmail.com> wrote:
>> Johan,
>> It is good to hear about the progress you are making with MapGuide. Which
>> version of MapGuide would be included if you are able to get it packaged?
>> Also,
>> I'm very keen to get a Project Overview write up for FDO. FDO is the only
>> OSGeo library which doesn't have a Project Overview. Is there any chance
>> you might be interested in writing it?
>> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Documentation
>> On 10/11/2012 1:12 AM, Johan Van de Wauw wrote:
>> I'll have another go at trying to get mapguide on the live dvd. I managed
>> to package fdo already (though the package still needs some finetuning),
>> and space usage decreases a lot if we use shared libraries.
>> https://launchpad.net/~johanvdw/+archive/mapguide/+build/3957203<https://launchpad.net/%7Ejohanvdw/+archive/mapguide/+build/3957203>
>> On Fri, Nov 9, 2012 at 8:54 AM, Cameron Shorter <
>>> Hi all,
>>> We have started the OSGeo-Live build process for the next 6.5 release
>>> and would like to know which version of each application we should include
>>> on OSGeo-Live.
>>> For the application(s) which you are responsible for, could you please
>>> email me with the version that you expect should be installed.
>>> If you will be changing the version of your application, could you also
>>> update the installers script.
>>> Our key milestones are:
>>> 10 Dec 2012 All new applications installed, most old applications
>>> updated
>>> 24 Dec 2012 Feature Freeze (all apps updated)
>>> 28 Jan 2012 User Acceptance Test (all apps installed and working)
>>> 18 Feb 2012 Final ISO sent to printers
>>> Cameron Shorter
>>> Geospatial Solutions Manager
>>> Tel: +61 (0)2 8570 5050 <%2B61%20%280%292%208570%205050>
>>> Mob: +61 (0)419 142 254 <%2B61%20%280%29419%20142%20254>
>>> Think Globally, Fix Locally
>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>> http://www.lisasoft.com
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Cameron Shorter
>> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
> Cameron Shorter
Blog: http://themapguyde.blogspot.com
LinkedIn: http://www.linkedin.com/in/jackieng
Twitter: http://twitter.com/jumpinjackie
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20121123/bf456abe/attachment.html>
More information about the Live-demo
