[Live-demo] OSGeo live DVD (6.0)
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Sep 14 02:15:07 PDT 2012
On 09/14/2012 04:53 AM, Hamish wrote:
> Hi,
> fwiw, in general I'd suppose a special 64 bit build is not worth
> the effort.
> my main question is why is it needed?
> for the minor performance boost from increased access to
> registers? (erm, remember you're working over usb2 or cdrom ...)
> or is anyone planning to use the live(demo)dvd with multigigabyte
> datasets?
> if not, what's the use except for bragging rights that this one
> does 64bits?
> I guess the main ones are people installing from the disk to a
> hard drive to use as their everyday system, and >4gb RAM used as
> disk cache is a nice place to be.
> Anyway, there are many prebuilt wgets for 32 binaries, I'd
> hope they'd all work on a 64bit system, but I can't guarantee
> that all the needed shared libraries will still be there and
> where they expect them to be. Probably we'd have to install all
> the 32bit compatibility libraries too, which may be a bit of a
> drain on the disc space.
> 2c,
> Hamish
> ps- java projects looking to make themselves into .debs might
> have a look at JOSM. I can't speak to the quality of the packaging
> or the approach, only that it is java, it is geospatial, and it
> is in debian & ubuntu already.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
As we discussed yesterday, a 64bit build would benefit only users that
install the disk into a hard drive. Almost all systems today are 64bit
and support >4GB RAM. So it would be nice to support those
installations, and I have seen a few around...
I agree that it is not worth the effort from the live disk perspective.
I suggest to make a test build at some point and see what works (the way
chroot method also started)
I also had in mind that bringing in 32bit compatibility packages would
kill us space-wise...
Cheers,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo
