[Live-demo] create pdf documentation
maning sambale
emmanuel.sambale at gmail.com
Thu Sep 27 02:41:50 PDT 2012
I also tried converting the docs to pdf but never get around to
finishing it. Solutions I did on some issues:
1. Large icons - To guarantee equal size, the size must be specified
in "real" units (cm, pt,
inch) not in relative units (em, px). i.e.
.. image:: image.png
:align: center
:width: 300 pt
2. Manual page break for each application page - I add this to create
manual page break at the end of each rst file:
.. raw:: latex
\pagebreak[4]
On Thu, Sep 27, 2012 at 5:41 AM, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
> On 26/09/2012 11:05 PM, Luca Delucchi wrote:
>>>>> I already try something but I have to work on it.
>>>>> Right now the simple way (that I see) to create a good html and pdf
>>>>> (pdf only for one language) documentation is:
>>>>> - rename index.rst to index.template and copy index.template to
>>>>> index.rst during compilation (I already try it and it works well)
>>>>> - create a index_pdf.template, copy it to index.rst and substitute a
>>>>> variable to set the language required for PDF file during compilation
>>>>> (I'm trying this but sed doesn't work)
>>>>> what do you think about this solution?
>>> This solution might be suitable, but I'm failing to understand the need
>>> to
>>> rename index.rst
>>> What is wrong with having a index_pdf.rst alongside index.rst?
>> because sphinx read index.rst and not index_pdf.rst. Your idea was
>> also mine but I discover that it doesn't work. If someone as a better
>> idea or working solution he is welkome
> Ok, if you can't pass in the filename of the starting page into RST as a
> parameter, then your suggestion above of replacing doc/index.rst above makes
> sense. Please go ahead and implement if you wish.
> Frank has been helping with the RST doc generation process, and might have
> some suggestions too.
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
More information about the Live-demo
