[Live-demo] [OSGeo] #1120: gpsbabel works only as root
OSGeo
trac_osgeo at osgeo.org
Sun Apr 7 23:41:33 PDT 2013
Reporter: micha | Owner: live-demo@…
Type: enhancement | Status: new
Priority: normal | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: gps, gpsbabel, GPSTools
Comment(by hamish):
micha wrote:
user at IAEA-Tutorial:~$ ll /dev/bus/usb/001/003
crw-rw-rw- 1 root plugdev 189, 2 Apr 7 10:25 /dev/bus/usb/001/003
is that before or after the adding the udev rule?
'plugdev' was not on the list of groups to sign the user up to in
setdown.sh, I've just added it in r10101.
Try:
sudo adduser user plugdev
then logging out and back in again, then plugging in the GPS.
> I also tried gpsdrive (uses gpsd) and my GPS was not recognized...
you don't mention, so just in case: gpsd must be started manually,
gpsdrive doesn't launch it for you; see the gpsd man page for details.
(auto-probing some Bluetooth GPSs can put the device in an unstable state)
what model garmin is it?
does 'dmesg | tail' give any other hints?
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1120#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
