[Live-demo] [OSGeo] #1122: Around 19.5 GB limitation
OSGeo
trac_osgeo at osgeo.org
Wed Apr 10 13:10:17 PDT 2013
Reporter: liam | Owner: live-demo@…
Type: task | Status: new
Priority: normal | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: limitation, install, vps
Comment(by hamish):
as a work-around you might check if there is a "compress filesystem"
option from the advanced partition tool setup when you're installing to
the VPS. the filesystem on the live dvd is compressed, as it is if you
install to a USB stick, so will expand to 2x size or more once put on what
it thinks is a real hard drive.
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1122#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
